Thread: Spanner light on ignition - 3.2 V6.
    Jul 2009
    Australia
    Default Spanner light on ignition - 3.2 V6.
    Just noticed a small problem today. When I start my car, the spanner and car symbol lights up for a second and then goes away straight away. It doesn't stay on, the car drives like normal, no power loss etc.
    What could this be? Don't want to take it to a dealer. Read that this might be a small problem detected by the ECU that isnt major in any way.
    Some people suggest unplugging the battery for 30mins and seeing if the problem stays.
    Any suggestions?
    05 Vectra C
    52 000km
    3.2 V6 Auto
    Oldbury
    That would be your glow-plugs mate..... Mine have needed changing for about 6mths now.
    Till you change them, before you turn over the motor, flick into pos.2 maybe 2/3 times then start it up. Gives the plugs a chance to warm and limits more damage to them. HTH
    Nov 2009
    tredegar
    if you have a petrol it is probably a little hiccup with the immobiliser and the spanner and car light should go off after 20 - 30 "cleans" starts, it happened to me a few weeks
    Jul 2009
    Australia
    also had it for a while, but it resolved itself after a handful of starts
    Regular Member MalcGSI's Avatar
    E Sussex & Kent
    The 3.2 doesn't have glow plugs as it isn't a diesel!!!!
    Just means that a fault code has been stored, it should stop happening after 15 or so starts. If the light remains on or comes on when driving the you have a problem and need to get to a garage ASAP.
  1. Light at ignition off
    By kingarthas in forum Electrical & ICE (including SatNav)
    Last Post: 11th May 2011, 17:43
  2. Light come on when key is put in the ignition!!!!
    By stuart813 in forum Electrical & ICE (including SatNav)
    Last Post: 5th January 2011, 11:43
  3. Spanner and Car light when ignition is on
    By ali06 in forum Engine & Drivetrain
    Last Post: 1st August 2010, 20:21
  4. Info light on, ignition off Strange
    By speednut in forum Electrical & ICE (including SatNav)
    Last Post: 25th April 2010, 21:50
  5. Ignition Circle Light
    By CristianTM in forum Styling
    Last Post: 17th April 2009, 06:50
vectra c 3.2 spanner light
vectra spanner light staying ignition is on
warm starting problems vectra c 3.2 v6
