Results 1 to 10 of 28
Thread: Vectra 1.9 150bhp - Spanner light ON!
    Regular Member Princess D's Avatar
    Sep 2010
    Anglesey
    Engine : 1.9 120bhp
    Mileage : 28k
    Cool Vectra 1.9 150bhp - Spanner light ON!
    Vectra 1.9 150bhp
    My spanner light comes on everytime I start the car but only stays on until I've driven it for a few minutes then goes off and doesn't appear again, this is usually when I first start the car up or after not using it for a few hours. Doesn't cause me any problems as far as I know and it passed all the computer tests!
    just the light is bugging me! I've just had it fully serviced aswel!
    Any ideas why it keeps coming on? previous owner said something about the glows???
    Jan 2010
    wirral
    glow plug fault.....more than likely need replacing
    preston
    agreed !
    easy job to replace all four.
    do it soon before the cold weather kicks in.
    while your there messing about
    remove your egr valve / boost sensor + clean
    an hours work that will save money and keep it running sweetly
    Jul 2010
    rotherham
    Mine does the exact same. But when i start mine it feels like it is struggling for aabout 10 seconds and i get abit of white smoke, Then the light goes of after a minute tops and runs fine.
    How much are a new set of glow plugs and are they easy to replace.
    Sep 2010
    Anglesey
    Engine : 1.9 120bhp
    Mileage : 28k
    Thats great guys thanks for the advice I will get straight on that and let you know how it goes!
    Jan 2010
    Preston
    Quote Originally Posted by Princess D View Post
    Hi There
    Was it the glow plugs?
    I have the exact same issue with mine spanner light on for approx 1.5 miles.
    preston
    glow plugs are needed as as diesels use compression ( and thus heat ) to cause the fuel to combust.
    glow plugs generate heat.
    hence they are needed more in winter as the engine block is cold and thus more heat is needed to ensure opeating temparature is realised
    on the 150 they are located on top of the engine between the injectors and the inlet manifold
    easy job to replace - follow the how2
    you'll need a 9mm deep socket to get them out
    good luck
    West
    Part no: 93178411 & are about £11 each plus vat from a dealer
    Sep 2010
    Anglesey
    Engine : 1.9 120bhp
    Mileage : 28k
    Hi, Changing them this week been too busy with work but I'l let you know how I get on! as dh.dti said they were just over £11 each plus VAT!
    Sep 2010
    Anglesey
    Engine : 1.9 120bhp
    Mileage : 28k
    I changed the glow plugs and the light has gone
  1. Vectra 1.9 150bhp - Spanner light ON!
    By Princess D in forum Vectra C / Signum Troubleshooting
    Last Post: 8th September 2010, 02:01
  2. Vectra 2004 ls dti spanner light help!!
    By jediknight in forum Vectra C / Signum Car Chat
    Last Post: 15th September 2009, 09:44
  3. Vectra 2004 ls dti spanner light
    Last Post: 14th September 2009, 19:20
  4. Spanner light coming on Vectra SRi 1.8 Y reg
    By coolesmudge in forum Engine & Drivetrain
    Last Post: 9th January 2009, 09:06
  5. Vectra c 2.0 DTI car and spanner light on
    By kman247 in forum Introduce yourself.
    Last Post: 20th December 2008, 19:26
