Results 1 to 10 of 13
Thread: Vecta hatchback - annoying rattle from the rear
    Aug 2010
    Buckinghamshire
    Default Vecta hatchback - annoying rattle from the rear
    New member. Car is two years old, 20k miles. Just purchased. Empty boot. And ....
    When driving slowly (30mph or less) something behind the rear seats is rattling/loose when I go over bumpy ground. Boot is firmly shut and I've checked all the plastic surrounds to the boot lid and boot and it seems fine. Partition seems fine too. I've even pushed the back of the car up and down whilst stationary and nothing.
    Any idea what it might be? Hoping its something you all know about and its just me that hasn't worked out what it is yet.
    Regards
    James
    Jun 2009
    South Coast
    8 Post(s)
    Vehicle : Signum & Insignia
    Engine : POS derv
    rattling inner brake pads in the rear calipers possibly.
    welcome to Vec C mate..
    Regular Member crespo's Avatar
    Bournemouth
    Its the boot catch. It needs adjusting. You can do it easy enough. Just pull away the plastic trim at the back of the boot where the latch is and undo the two torx fixings and lower the catch a few mill and re tighten, shut boot. Job done.
    I had this on my car and it drove me nuts for weeks before i found out what it was. I had the spare wheel out and everything.
    Even though the boot seems firmly shut its not.
    Dunstable
    I had this on my last vec, adjusted the boot catch and that sorted it. Also may be worth checking the parcel shelf to make sure it's not knocking as you're driving along.
    Bournemouth
    Quote Originally Posted by Caveman_nige View Post
    Unlikely. The car has only done 20k so will be on the original rear pads unless he bought it off Jenson Button.
    Are you VXR Enough
    13 Post(s)
    Engine : 6.0 V8 Thunder
    it could be the parcel shelf fella as there are 2 rubber bits that are supposed to stick out a bit to sit flush on the tail gate. it could also be the rear tailgate lock. or the rear seats have not been locked in place properly or the centre seat seatbelt hasnt retracted properly causing a rattle ive had all these affect my car fella
    Regular Member fingers66's Avatar
    Carpe Diem
    Quote Originally Posted by crespo View Post
    Wont be long till your rear pads need changing, mines went at 27K.
    Bournemouth
    Quote Originally Posted by fingers66 View Post
    WHAT!!!!! Do you drive round with the handbrake on. At the rate your going your going through rear pads quicker than rear tyres.
    Liverpool
    I get a rattle now and again, it's the 'catflap' access panel into the boot, maybe worth a look
    West Yorkshire
    My parcel shelf rattles so much I just leave it off the car (car has dark tints on anyways)
  1. Annoying rattle from rear of car
    By a_j_mair in forum Vectra C / Signum Car Chat
    Last Post: 16th September 2010, 12:53
  2. Annoying rattle
    By ironstone in forum Vectra C / Signum Troubleshooting
    Last Post: 14th January 2010, 14:13
  3. Annoying rattle
    By steve1975l in forum Vectra C / Signum Car Chat
    Last Post: 2nd January 2009, 22:31
  4. Annoying rattle
    By Tigger in forum Vectra C / Signum Car Chat
    Last Post: 17th January 2008, 11:03
  5. Annoying Rattle
    By ANDY GSI in forum Vectra C / Signum Car Chat
    Last Post: 14th May 2007, 18:04
vectra c back seat rattle
vectra c rattle rear compartment
vectra c rattle back seat
vectra c rattle door in back seat
