Results 1 to 5 of 5
Thread: Strange problem with starter, Help needed
    Regular Member platty's Avatar
    Jan 2008
    Paisley
    Default Strange problem with starter, Help needed
    Hi Guys I have a problem with my 1.9cdti (150) and really need some help.
    The problem is that occasionally my starter motor tries to engage whilst the engine is running, when this happens the car cuts out and the spanner light is thrown up. When the car is restarted it starts no problem and the spanner light disappears.
    I have had the starter checked and it is fine no sticky solenoid etc, My next thought is to change the starter relay and the ignition switch. The real problem is this fault is intermittent and it has only occurred twice in the last week so pinning down the fault is difficult.
    Could this possibly be cim? related, I don't really know much about control modules does this control the starter signal?. Is it worth putting the car in to see if there are any stored fault codes.
    Any Ideas would be greatly appreciated
    Cheers Platty
    Regular Member Das's Avatar
    Yer Maws Bedroom
    40 Post(s)
    Vehicle : Honda Civic
    Engine : 1.8 iVtec
    Mileage : 85000
    The starter relay would most likely be the easiest thing to change to start with.
    Jan 2008
    Paisley
    Thanks for the quick reply. I plan to change the relays tomorrow and hope that sorts it, but knowing my luck and this car I can see it costing me £'ss
    Yer Maws Bedroom
    40 Post(s)
    Engine : 1.8 iVtec
    Mileage : 85000
    If not easiest defiantly the cheapest mate. Something is shorting out and making the starter kick in, does it run for long when it kicks in?
    Jan 2008
    Paisley
    It usually sounds as if it kicks in for a few seconds, this is usually long enough to stall the engine. There was one point were it was on constant, i.e when you turned the key to posistion ii (ignition on) the starter would crank. Thats what is making me think sticky solenoid or relay.
  1. FIXED my starter motor myself but still have the other problem I need to fix....
    By wingz123 in forum Vectra C / Signum Troubleshooting
    Last Post: 9th June 2011, 21:19
  2. vectra 1.8 starter problem can you help
    By Les45 in forum Electrical & ICE (including SatNav)
    Last Post: 25th May 2011, 12:38
  3. Starter problem
    By m3trackboy in forum Engine & Drivetrain
    Last Post: 9th October 2010, 08:39
  4. z22yh help needed strange problem
    By matt0785 in forum Engine & Drivetrain
    Last Post: 12th June 2010, 13:33
  5. Help needed Vectra-C.. Starter motor or... ??
    By SRidale09 in forum General Chat
    Last Post: 22nd November 2009, 21:14
vauxhall vectra 1.8 petrol starting problems
