Thread: mystery illness makes car v poorly
    Sep 2010
    Lancashire
    Default mystery illness makes car v poorly
    Hi all - new to this so bare with me. My vectra is v poorly at the mo - its misfiring when in gear although not when idling, its not the plugs, they've been checked and changed, its had a coil pack on it (which made it worse) and a new fuel filter. Has anyone got any ideas before this gets very expensive? Have also had it on the diagnostic computer as the engine management light is on - this doesn't pick up anything it just says 'code not recognised'. Really dont want to take it vauxhall as they are not very good here - but i will do if absolutely necessary. HELP!!?? any suggestions will be gratefully tried out!!
    Jan 2010
    glasgow
    it could be 1 the fuel regulator, 2 the hp fuel pump, who read the codes and what with? i see its a 2.2 have u made sure its timing isnt out by a tooth? what code was it showing?ie number, it maybe be the egr thats dirty/sticking try and get some 1 with op-com or get it on a tech 2 reader there are loads of things that can make a car missfire some easy and cheap some very dear
    Jan 2010
    glasgow
    by any chance is it making a noise ? are u sure its a missfire? and not a judder/vibration? if it was a missfire it would be there on idle to, a faulty dmf would cause a judder u may be mistaking it for a miss fire, any ways change the fuel filter put redex in the tank and take it a good blast across the motorway see if that helps
    Regular Member rushy's Avatar
    Vehicle : SRi
    Engine : Z22SE (2.2 Petrol)
    Mileage : 137000
    That'll be your pump or reg mate. The Reg is covered under a recall but the pump isn't. If not done so get it into VX to have the Reg done under the recall, they should be able to tell you if the pumps gone. I take it you still have the Siemens pump not the new Continental one?
    Jan 2010
    glasgow
    if the regulator or pump was gone it it would be in limp home mode hence the eml lite mate so it will be very slow how is it wen your driving it?
    Vehicle : SRi
    Mileage : 137000
    You can drive round fine when the hp pump is on the way out. Many find its only when you give it some pasty that the eml comes on. If its in its early stages of coarse.
    Regular Member markj23's Avatar
    Aug 2010
    Luton
    just had mine done after about 6 weeks of messing around in and out of limp been In more garages than I care to think all mates of course, every time went on reader came up with something new. Ended up terminal stopping on A12 100 miles from home anyway bit the bullet recovered to main dealer 205 gbp later fuel pump pressure sensor back loving my baby!!
  1. Is it poorly?....
    By bobby-tupper in forum Vectra C / Signum Car Chat
    Last Post: 15th December 2008, 14:22
  2. Illness & bl**dy time of the year.
    By JKB89 in forum The 'Off Topic' room
    Last Post: 11th December 2008, 11:58
  3. Think I have an illness lol...
    By danBoy in forum The 'Off Topic' room
    Last Post: 22nd September 2008, 06:55
  4. car is poorly
    By andy.l in forum Vectra C / Signum Car Chat
    Last Post: 18th June 2008, 09:24
  5. Poorly VXR
    By MattB in forum Spotted or put a flyer on a Vectra C/Signum or Insignia?
    Last Post: 10th August 2007, 20:29
