Thread: Water in fuel warning light
    Sep 2010
    SHREWSBURY
    Default Water in fuel warning light
    HI I HAVE A 2.0 DTI VECTRA 2004 AND THE WATER IN FUEL LIGHT COMES ON FOLLOWED BY LACK OF POWER AND THE CAR CUTTING OUT. IT THEN RESTARTS AGAIN STRAIGHT AWAY AND THE LIGHT GOES OUT UNTILL IT NEXT HAPPENS
    I HAVE CHANGED THE FUEL FILTER BUT IT HASNT MADE ANY DIFFERENCE
    ANYBODY HAVE ANY IDEAS CHEERS LEE
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    Have you drained the filter housing of water? There is a drain screw underneath. It needs doing every year or so to remove any water from the fuel that collects there.
    Sep 2010
    SHREWSBURY
    Cheers i will try that tomorrow. Would this make the car lose power and cut out
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    If the separator is full of water and water is spilling over into the fuel delivery line to the pump, then it will cause issues. Mainly because water doesn't burn very well. It will also tned to cause wear to the pump etc, as the fuel is the pump lubricant.
    As to making it cut out, at speed, no, - at idle, maybe. Try draining the water off. You only need to drain about half a cup of fluid. Just make sure some diesel has come out and all the water will be out as diesel floats on water. (this is the principle of how the fuel / water separator works.)
    Sep 2010
    SHREWSBURY
    Hi i have drained the water out of the filter but the same thing is still happening
    the light on the dash will come on then a drop in power and cut out this can happen at 30mph
  1. engine warning light after fuel filter change
    By webtrawler in forum Vectra C / Signum Troubleshooting
    Last Post: 29th September 2012, 22:04
  2. '03 DTI - Do I Have a Low Fuel Warning Light?
    By AdeV6 in forum Vectra C / Signum Car Chat
    Last Post: 28th May 2012, 10:43
  3. Fuel warning light - how much left in tank?
    By gtr1000 in forum Vectra C / Signum Car Chat
    Last Post: 28th February 2012, 17:56
  4. Engine Fault Light - Water in Diesel Fuel Filter?
    By rharris21 in forum Engine & Drivetrain
    Last Post: 14th February 2012, 10:06
  5. Fuel level warning light......
    By Nik in forum Electrical & ICE (including SatNav)
    Last Post: 20th July 2011, 00:44
water in filter warning light vectra c
does a vectra 2.0 dti have a fuel water separator
jaguar xf 3.0d water in fuel light fault
