Thread: combi boiler ?
    Regular Member rickeys16v's Avatar
    N.Ireland ( Broughshane )
    Vehicle : 1.9 CDTI 150
    Trim : SRI
    Mileage : 46000
    Default combi boiler ?
    can anyone tell me how long a combi boiler should take to give me hot water its taking about 30 to 40 mins at the moment.
    Regular Member george1987's Avatar
    Nov 2009
    Plymouth/Southampton
    I've got one and it takes about three minutes and then the water is 80 degrees C. It takes the three minutes to get to the max temperature.
    Trim : SRI
    Mileage : 46000
    thanks george think its about time someone had a look at it
    Jan 2010
    wirral
    depending on the distance between the boiler and the hot water output location, ie, bathroom, kitchen etc it should never take more than a minute or two.....maximum.
    Infact, if its taking that long, I'm surprised its getting hot at all.
    Does it only get hot whilst central heating is on??
    Or can you get hot water WITHOUT central heating??
    Regular Member MalcGSI's Avatar
    E Sussex & Kent
    Combination boilers should give hot water almost straight away as the burner should ignite when the hot tap is turned on.
    Nov 2009
    There seems to be people with knowledge about combi boilers on here. Can anyone tell me why my heating comes on when having a shower or filling up the sink to wash up?
    E Sussex & Kent
    Not an expert by any means, just know what they are supposed to do. If your heating comes on when running hot water I would GUESS a valve is stuck, this might also cause the delay in your water warming up.
    Regular Member vauxhall-john's Avatar
    fife, scotland
    Quote Originally Posted by george1987 View Post
    im a gas heating engineer mate, sounds like the diverter valve on your combi is away, depending on the boiler make and model, could either be stuck or the diaphram is split,
    as for the first problem on this thread, what make is the boiler and how old is it? most combi boilers take roughly 2-3 mins to give full temperature to the hot water outlet, unless its got a heat bank then it will give you hot water almost instantly,
    Jan 2010
    wirral
    the diverter sounds like the culprit, or possibly DHW flow switch/turbine, as in the case of worcester 28i junior or similar, which don't have diverter valves. (I am also plumber/heating engineer)!!!!
    Regular Member keefy*2010's Avatar
    Jul 2010
    Grain, Rochester,Kent
    Vehicle : Vectra C Facelift
    Engine : 1.9Cdti 150
    Most newish Combi Boilers have separate water supply direct into the heat exchange, with central heating being on a closed circuit with top up link.
  1. combi boiler problem ??
    By bembo449 in forum The 'Off Topic' room
    Last Post: 4th February 2012, 10:20
  2. Noisy Boiler
    By crispy007 in forum General Chat
    Last Post: 21st November 2011, 18:52
  3. Combi Boiler!
    By djr69uk in forum General Chat
    Last Post: 5th March 2011, 02:04
  4. Duff Boiler.....
    By macdad in forum General Chat
    Last Post: 23rd February 2008, 21:38
  5. Help...Combi Boiler
    By Damian in forum General Chat
    Last Post: 13th April 2006, 18:48
