Results 1 to 4 of 4
Thread: Doggy read bulbs
    Sep 2010
    Oxfordshire
    Default Doggy rear bulbs
    Has anybody had any problem with the rear lights (brake and side lights).
    The bulbs were intermittent and dull so when I replaced them I found that the nipple bit on the back of the bulb (don’t know the technical name but sounds good) had melted and caused the problem.
    Will this keep happing or had a previous owner used cheap bulbs.
    Regular Member Ademusic's Avatar
    Dunstable
    No problems that I've ever heard of with the bulbs themselves. The nipple bit you talk of is only solder I believe so can easily be worn down as it's only a soft metal. If there was a bad connection in the first place, it could've caused arcing on this connection and melted the solder. Replace the bulbs and see how it goes
    Sep 2010
    Oxfordshire
    Done will keep an eye on them
    Regular Member keefy*2010's Avatar
    Jul 2010
    Grain, Rochester,Kent
    Vehicle : Vectra C Facelift
    Engine : 1.9Cdti 150
    It is quite common for the solder to become blackened.
    When you put new lamps in make sure you clean the brass connect/tab within the housing a little bit of vasaline on them also helps
  1. Doggy brake pads?
    By sla002 in forum Suspension, Wheels & Brakes
    Last Post: 27th August 2011, 12:56
  2. Do you have a doggy too?
    By Vectralicker in forum General Chat
    Last Post: 27th October 2010, 11:39
  3. woops doggy pallet
    By Niall83 in forum The 'Off Topic' room
    Last Post: 17th April 2010, 21:47
  4. Another gratuitous cute doggy picture.
    By SignumPhil in forum General Chat
    Last Post: 21st November 2008, 17:41
vectra display draining battery
