Page 1 of 4 123 ... LastLast
Results 1 to 10 of 33
Thread: sri 150,how much more bhp?
    Nov 2009
    newcastle upon tyne
    Default sri 150,how much more bhp?
    As above,ive had mine remapped by pd tuning and it has made a difference ie no flat spots in 1st or 2nd but how much more bhp can i get out of it without encountering problems?.....Ive done the airbox mod c/w panel replacement filter and he's running sweet but i'd really like to go faster but not spend 100's and 100's.My next thing is go back to pd tuning and get it on the rollers to check the bhp.
    Regular Member Rab's Avatar
    Irvine
    next mod would be an exhaust and decat with a custom map. shud be 200bhp. 200bhp is the magic number.
    Nov 2009
    newcastle upon tyne
    I reckon i must be kicking around the 170 mark now?...But with custom exhaust and decat dont tht mean alot of noise and probs with mot?....i certainly dont want a loud system.
    Aug 2009
    sheffield
    next mod would be a racing clutch . just killed my 1.9cdti 150 clutch,with more bhp.BE WARNED.
    Jan 2010
    Perkinsville, County Durham
    Trim : Sri nav
    Engine : Z19dth
    Were pdtuning busy as ever? They always seem to be rushed off their feet when i pop in.
    member of the smoke patrol 230bhp+
    your map should be around 150 bhp @ the wheels if it is the map is ok if it below that it may be something thay need to look at
    EVERYWHERE
    You can get 230 bhp out of it no problem at all.
    Some things to consider though:
    1. Change oil and filter at about the same intervals you would on an Imprezza STI i.e. every other week.
    2. Bits attached to the engine (clutch/DMF/gearbox etc) may not take too kindly to nearly 50% more torque.
    3. You may also wonder why everything is happening so frantically for not that much more noticeable forward motion as you quickly make your way through the lower gears, only later to discover that your overall gearing is lower than that of a Vectra 100 cdti!
    But don't let that put you off. More power is more power.
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Engine : 2.0 TDI 184PS
    Mileage : 40000
    As above 230 on this engine but that is close to the limits of the internals tbh.
    DMF shouldn't be too much of an issue, as the DMF works hard during engine starting and easily damaged should the clutch not be disengaged. My DMF has been on the rattle for 84k+ now, can't deny it's getting a bit worse.
    Clutches will be a problem in terms of life and to my knowledge there isn't an upgraded one available.
    Gazza4
    EVERYWHERE
    Quote Originally Posted by Gazza4 View Post
    DMF has friction clutch that's supposed to let go first. Some let go earlier or later than others though. But whatever happens, something will eventually let go. *waits for: "Mine has 500 pounds of torque and it's still OK." type replies.*
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Mileage : 40000
    Quote Originally Posted by diesel dog View Post
    No mine has 232lbft but 3 years on this forum and I haven't read of any going, but I await reply saying 'found one'
    Gazza4
how do i get more bhp out of my vectra c sri
