View Poll Results: Front Camber Bolts Fitted...
Voters
6. You may not vote on this poll
  • Yes!!
    1 16.67%
  • No...
    2 33.33%
  • Camber Bolts?!?... lol
    3 50.00%
Thread: Front Camber....
    Forum Moderator Leemarksmith's Avatar
    Hanging Heaton / Batley
    11 Post(s)
    StatsVehicle Info
    11 Post(s)
    Default Front Camber....
    How many of you have fitted the camber bolts to the front, and had it adjusted after lowering?
    Getting Alignment/camber done finally in a few week and just wondering weather to bother with the front bolts, only looks slight compared to the back... Its lowered 45/40 on PI's...
    Please only vote "IF" you have lowered yours...
    11 Post(s)
    StatsVehicle Info
    11 Post(s)
    Anyone... lol
    Forum Moderator John LE's Avatar
    Forfar, Scotland
    StatsVehicle Info
    Nope, not even had the geometry set up on mine after a "30mm" drop on eibachs as the car still drives the same and tyre wear is even. With a drop as much as that however yo may need em
    Regular Member rushy's Avatar
    StatsVehicle Info
    Exactly the same as John mate.
    Tyneside
    StatsVehicle Info
    Lowered on H&R springs with Bilstein B$'s and front camber bolts. Had a full geometry set-up on a hunter system which is expensive, but I got discount with another club. You probably don't need the camber bolts, but they don't cost much and if your getting a full set up of the camber, toe, caster etc you might as well pay the few quid imho
    Regular Member Thunder's Avatar
    Apr 2008
    North Yorkshire
    StatsVehicle Info
    30mm drop on eibachs & full geometry check-up was fine (no adjustment needed)
  1. Replies: 15
    Last Post: 4th April 2012, 13:50
  2. Front Camber Adjustment
    By moneypit in forum Suspension, Wheels & Brakes
    Last Post: 19th July 2011, 11:56
  3. Camber? Camber Kits??
    By RyanNI in forum Handling & Braking
    Last Post: 13th December 2010, 11:11
  4. Front camber adjustment?
    By Tayla in forum Handling & Braking
    Last Post: 13th November 2010, 14:01
  5. Front camber adjustment?
    Last Post: 11th November 2010, 17:56
