Thread: 2.2 auto gearbox problem
    Sep 2010
    leicestershire
    Default 2.2 auto gearbox problem
    Hi all,
    i have a 52 plate vectra C 2.2 LS and the auto box has developed a problem.
    when its cold it jerks when slowing down from 3rd to 2nd once warm its ok.
    now yesterday once the car wa hot the box went into some sort of safe mode. and was like stuck in one gear. i switched over to semi auto an could only select 5th or 2nd.
    if i turn the engine off then on again its okay again for a few miles.
    Would a oil change help as i dont know when it was last done, but it has full VXSH done 68K miles
    please help
    thanks
    NIGHTCD
    Guest
    probably an oil change will do .. but you have to buy some oil from the stealers,.. do not use anything else.
    ps. do you have checked if the oil is at max on the dipstick ?
    london
    Start with getting the oil changed . ATF 3309 oil also used in toyota and saabs. If the oil hasn't been changed up to 68k miles, that could be the cause as there will be little lubrication left.
    Sep 2010
    leicestershire
    thanks for the replys guys.
    ive checked the engine oil dipstick and thats on max, i didnt know the gearbox had a dipstick.?
    i will take to vauxhall on monday and see if they can help, i will mention doing a oil change to them.
    Sep 2010
    leicestershire
    booked in for tech 2 on thursday.
    however the spanner light came on today and i used my scangauge 11 out of my rx8 and it displayed BA222. does anybody reconise this?
    the fault has cleared ....for now
    Sep 2010
    leicestershire
    coolant in the gearbox
    gearbox + rad needs replacing £2.5k+
    only had the car a month!
    Regular Member nibblitz's Avatar
    Jul 2010
    Buckinghamshire
    Oh no, thats terribly bad luck matey.. That sort of repair cost has wrote the car off then I guess, or did you buy your car from a dealer with any sort of warranty..
    london
    There was a recall on that issue by vauxhall some years back, did mine under the recall programme .
    The radiator seal fails and let coolant in the gearbox ruining the system, i think.
    its just a bad luck
    Sep 2010
    leicestershire
    Spoke to the dealer I got it from and he thinks vauxhall are trying to scare me. So he's arranged for a local garage to do a gearbox fluid change.
    He wants to do this before negotiating my money back for the car. So going to garage tomorrow for this. I know it's a waste of time as it also will need a new rad.
    I asked vx about the recall but didn't get very far
  1. 3.2 V6 auto gearbox problem!!!!!!!!!!
    By deltapapa in forum Engine & Drivetrain
    Last Post: 9th March 2012, 23:40
  2. 2.2 vectra c auto gearbox problem
    By Paddy in forum Engine & Drivetrain
    Last Post: 12th March 2011, 18:54
  3. auto gearbox big problem
    By driveryte in forum Engine & Drivetrain
    Last Post: 6th July 2010, 13:50
  4. Help please !! 2006 Auto gearbox problem
    By n1nlt in forum Engine & Drivetrain
    Last Post: 17th March 2010, 23:29
  5. Auto Gearbox Problem 2.2 SXI 52 plate
    By WeDesign in forum Engine & Drivetrain
    Last Post: 21st January 2008, 18:40
vectra 2.2 auto problems
vectra c auto gearbox problems
vauxhall vectra c automatic gearbox problems
vauxhall signum automatic gearbox problems
signum auto gearbox problem
https:www.vectra-c.comforumshowthread.php117377-2-2-auto-gearbox-problem
vaxhall vectra c auto gear box problems
opel zafira 2.2 auto gearbox
vauxhall zafira 2.2 automatic problems
Vectra auto 3 gear www.vectra-c.com
2006 vectea auto box
vectra 2.2 automatic judder
opel vectra 2.2 automatic probleme
vectra automatic gearbox problem review
opel vectra automatic problem
opel zafira 2.2 automatic gearbox
signum 2.2 auto gearbox problem
find vectra c gearbox auto 2.2 diesel
vauxhall signum gearbox problems
vectra c gearbox problems
vectra slipping gears automatic trans
vauxhall vectra 2.2 auto gearbox problems
