Results 1 to 10 of 18
Thread: Intermittent warning lights
    Regular Member juggernaut's Avatar
    Rugby
    Default Intermittent warning lights
    Every now and again, usually when performing a slow speed manoeuvre such as parking I get two amber warnings on the dash, one is a steering wheel with an exclamation mark next to it and the other is the traction control I think, (car having a skid). It has no obvious effect on the car and goes away when I turn it off and back on again. Any ideas please?
    member of the smoke patrol 230bhp+
    you need to get this looked at as there maybe a small prob with your steering motor ,
    if its just electrical you going to be ok with just a update but there is a list of things it could be
    When this happens, put one of the indicators on
    You should find it will not cancel
    If this is the case, then the CIM module has failed
    Otherwise it may be one of the front hubs / sensors
    Vehicle : vectra-c
    Trim : sri
    Engine : cdti
    Mileage : 98,000
    It would also be a good idea just to check the power steering level!.
    Are you VXR Enough
    13 Post(s)
    Engine : 6.0 V8 Thunder
    Quote Originally Posted by the-wizard View Post
    check the fluid level on the steering fella
    The hint in this fault is the Traction Control warning light also coming on
    Starts off intermittent, then happens every time you turn left or right
    Confirmation is completed by putting that indicator on, which refuses to cancel
    Rugby
    Will check fluid level. CIM module, what's that? Thanks for all the other answers
    Rugby
    tried the indicators and they cancel, so its fluid level check now I guess?
    Quote Originally Posted by juggernaut View Post
    No, check both front hubs
    From memory the nearside one has a sensor on it, and this is the one that may have failed, which gives this fault message; power steering and traction control
    Rugby
    Finally got around to checking the power steering fluid and it was below the minimum mark (no signs of leaks) so topped it up. I now have same warning lights but in a different order.
    1. Traction control light illuminates on its own now and it's almost as if it's on a timer because it will come on after about 30 minutes of driving.
    2. Turning the car off and on again will not reset it like it used to when both warning lights came on together, however if left overnight it does go out but then we're back to no.1 again.
    3. Occasionally the steering wheel light will join the party especially if it involves slow speed manoeuvring such as parking and the steering goes a little heavier. However steering wheel light will extinguish and leave the traction control light illuminated.
    4. So far the steering wheel light has not illuminated on it's own.
    This is now driving me nuts
  1. Strange intermittent left fog lamp warning
    By rheumatoid in forum Electrical & ICE (including SatNav)
    Last Post: 19th May 2012, 12:02
  2. How 2 solve intermittent hatch open warning
    By meccano in forum Bodywork & Interior
    Last Post: 13th February 2012, 14:09
  3. Intermittent electric issue to do with rear lights
    By ad13 in forum Electrical & ICE (including SatNav)
    Last Post: 3rd October 2011, 12:54
  4. intermittent check rear bulb warning
    By parttimer1 in forum Vectra C / Signum Car Chat
    Last Post: 21st June 2011, 19:33
  5. Intermittent battery and steering warning lamp
    By Rapier in forum Electrical & ICE (including SatNav)
    Last Post: 3rd October 2009, 18:15
u2142 yaw rate sensor no communication permanent
