Thread: Problem... HELP!
    Jul 2006
    Northampton
    Trim : Sri
    Engine : 1.9 cdti 150
    Default Problem... HELP!
    Hi guys, i have recently been getting problems resulting in the spanner light that doesnt go away. It usually happens when i stop or am idle. When i had the codes read before it come up saying boost sensor and solenoid. How much is the boost solenoid and is this the problem? Anybody help?
    EDIT: also, where is it so i can replace it?
    I guess you haven't cleaned it yet then?
    Jul 2006
    Northampton
    Trim : Sri
    no not the sensor but the spanner light is on when i turn the car on
    Devon
    77 Post(s)
    Vehicle : insignia
    Trim : irmscher
    Circled in yellow
    Irmscher Insignia CDTI 130
    Jul 2006
    Northampton
    Trim : Sri
    Thanks guys, i had the rac read the codes tonight and they said they were P1105 and P0105
    Jul 2006
    Northampton
    Trim : Sri
    Quote Originally Posted by bigmac View Post
    Circled in yellow
    Thanks Don, do you know how to get it out or is it the same as the cdti how 2?
    Regular Member Daywalker's Avatar
    Aug 2007
    Kaunas raj
    Vehicle : Qashqai
    Trim : Visia
    Engine : 1.5dci
    Year : 2010
    Dan you just need to remove the engine cover (3 torx screws) then undo the electric clip then use a 8mm ring spanner to undo the torx bolt (be careful not to drop it). Once out you will see a little cage with the sensor ( looks like a grain of rice) gently clean it using a small paint brush and some carb cleaner or let it soak in some WD40. HTH
    Vehicle : Signum 2.0 DTi
    Trim : Elegance/Elite
    Engine : 2.0DTi
    Mileage : 73350
    Danwells your p1105 code relates to your secondary vacuum sensor circuit and your po105 is boost pressure sensor . so i would start looking in the area of your vacuum hose connectors for leaks and splits the p1105 fault may be indicating that one of your actuators is going faulty
    Jul 2006
    Northampton
    Trim : Sri
    Thanks for the help guys, i have cleaned the sensor and sorted all the vacuum pipes and now its working again. It makes such a difference its unbelievable! Really does pull like train!
  1. Rear Signum Light problem problem - help
  3. 1 problem sorted and 1 more problem arises
    Last Post: 4th April 2011, 13:03
  4. Bit of a problem, Need Help
    By vectrasri-j in forum Vectra C / Signum Car Chat
    Last Post: 18th January 2010, 19:21
  5. Problem...? Vectra SXI...problem with starting after filling with fuel?
