Thread: dash problemo ( light )
    corby
    Default dash problemo ( light )
    i have a light in the dash with a car and a spanner i took it to a garage and put a diagnostic on it but it is still on it, any suggestions wot it cud be, the mechanic wiped the codes but it still wont budge any help would be appreciated
    Admin & Merchandise Manager bigmac's Avatar
    Devon
    72 Post(s)
    Vehicle : insignia
    Trim : irmscher
    The mechanic should of told you what the code was lol that way you can sort the problem out as its still showing
    Go back and ask him to read the code
    Irmscher Insignia CDTI 130
    Dunstable
    As don said, the code relates to whatever the problem is with the car. It's no good just reading and clearing the code, the problem needs to be rectified otherwise it'll keep putting the light on. Get him to read the fault code again and diagnose the problem. The code he reads will point him in the direction of where the fault is.
    Oct 2009
    portland
    Vehicle : Bmw 330d
    Trim : Msport
    Engine : 3.0d
    easiest way out
    Regular Member LADmachining's Avatar
    Hampshire
    Even easier, try the 'pedal test' to read the fault codes for yourself.
    Press and hold brake and accelerator pedals down as far as they will go with the ignition off.
    Switch ignition to position 2 so dash lights come on, but do NOT start the engine.
    Wait a few seconds - either the codes will appear in the mileage display as "ECN xxxx yy", or the engine management / spanner light will flash out the code to you.
    Example:-
    If it flashes ten times - pause - three - pause - three - pause - five, then the code stored is 0335.
    Post back here any codes you find...
  1. light on dash
    By Nessy in forum Vectra C / Signum Troubleshooting
    Last Post: 6th June 2012, 02:38
  2. Gearbox oil problemo
    By Mikey4996 in forum Vectra C / Signum Car Chat
    Last Post: 12th March 2012, 21:45
  3. Got a Problemo.
    By adam_starkie in forum Engine & Drivetrain
    Last Post: 17th March 2011, 15:58
  4. 3 button key problemo
    By Silver Vectra C in forum Vectra C / Signum Car Chat
    Last Post: 8th July 2010, 07:17
  5. tc dash light
    By gromit in forum Electrical & ICE (including SatNav)
    Last Post: 3rd November 2008, 20:53
