Thread: rear level of signum
    wellingborough
    Default rear level of signum
    looked at both sides of rear of signum and gap between top of tyre and wheel arch differs by about 5 mm, i did have my shocks changed a few months ago and am now wondering whether only 1 side was changed by garage as initially only 1 side was leaking.
    any ideas many thanks
    nick
    Jun 2009
    South Coast
    Vehicle : Vectra, Signum & Insignia
    Engine : Z18XE,Z19DTH,Z20NET,
    5mm, thats not much.. is the side that was busted the one thats higher? Is the drivers side that higher or lower?
    The wifes vec show car is currently being stripped for parts before i scrap it, keep an eye on the sales section.. https://www.vectra-c.com/forum/garage_vehicle.php?do=view_vehicle&id=709
    wellingborough
    yes the side thats higher is the one that was initially leaking
    wellingborough
    drivers side is higher
    Jun 2009
    South Coast
    ok.. first thing to do is to jack up the back of the car and have a look at the shocks, they should both look to be the same age, if not then you may be correct in your assumption that only one was done? Have you measured from the wheelarch to the ground as well instead of just to the tyre.. take a pic of the shocks if you can and post them here, the guys here will give more advice, but you need to be sure before you go back to the fitters with your concerns.
    wellingborough
    measured from centre of alloy as ground not too level. will take pics and upload tomorrow
    thanks
    Jun 2009
    South Coast
    well, it can't hurt to have another measurement just in case..
    Aug 2010
    Derbyshire
    Quote Originally Posted by niicckk View Post
    thanks
    Get it on level ground to measure, and have you anything heavy in the boot such as a toolbox?
    Mick
    I would say that shocks wont increase or decrease the height that the car sits from the ground, thats the job that the springs are there for. ( unless you have coilovers fitted ) Have you checked for a broken bottom/top coil on both rear springs.
  1. Replies: 5
    Last Post: 5th February 2012, 20:42
  2. Auto rear level control on vectra wagon
    By zafira in forum Suspension, Wheels & Brakes
    Last Post: 28th June 2011, 16:22
  3. Automatic level at the rear
    By sliderke in forum Suspension, Wheels & Brakes
    Last Post: 20th January 2011, 15:25
  4. High Level Brake Light on Signum 2.0T
    By neskemi in forum Electrical & ICE (including SatNav)
    Last Post: 8th November 2010, 09:56
