Results 1 to 3 of 3
Thread: access to pulleys?
    Regular Member neill's Avatar
    Nov 2009
    Warrington
    Trim : SRI
    Mileage : 172000
    Default access to pulleys?
    how do i gain easy access to the pulleys on a 1.9cdti 150? as i suspect that one of them is about to fail?
    cheers
    Bristol
    Vehicle : CDTI 150
    Hi,
    Why do you think a pulley is on its way?
    The crankshaft pulley is accessed by removing the front drivers wheel then the wheel arch liner, its also best to remove the airbox so that its a bit easier to get to the tensioner; this will also allow better access to the top end pulleys.
    Good idea to use either your moby or digital camera to take a pic of the routing for reference.
    Nov 2009
    Warrington
    Trim : SRI
    Mileage : 172000
    Quote Originally Posted by lesj View Post
    Hi,
    because i keep here a rattling sound coming from the pulley area, had a look today and i think it may be tensioner that makeing the noise
  1. X18XER cam setting after renewing belt and vvt pulleys
    By Andy-G in forum Engine & Drivetrain
    Last Post: 14th September 2012, 00:14
  2. wyning pulleys
    By djdee in forum Engine & Drivetrain
    Last Post: 9th July 2011, 12:09
  3. 120 and 150 fuel pump pulleys the same?
    By lee gsi in forum Engine & Drivetrain
    Last Post: 13th November 2010, 17:38
  4. Damper pulleys
    By the-wizard in forum Engine & Drivetrain
    Last Post: 1st August 2010, 09:56
  5. New pulleys?
    By Stevie-B in forum Vectra C / Signum Car Chat
    Last Post: 30th July 2008, 09:49
