Thread: +'ve terminal heating up
    Regular Member Cam's Avatar
    Sep 2009
    Fife
    Default +'ve terminal heating up
    Help!!!!
    I'm at a loss, I've changed the Battery and the Alternator on my V6 Vec B and it's still doing it whilst it's running, strange thing is, if I take the Aux belt off it doesn't heat up at all when its running, any ideas please
    Dunstable
    Got the correct alternator fitted? If the wattage is higher it could be sending too much current down the wires? Just a guess
    Aldermaston (Berks)
    Surely if you take the aux belt off the altenator it would not be charging the battery hence it will not heat up. I had the same problem on an old cavalier sri, it turned out to be the wiring, it had lost all resistance.
    If i were you i would be checking all main wiring & earthing points, silly question was the battery and the altenator brand new or second hand?
    Sep 2009
    Fife
    The battery that was in was new in December and was replaced last week for a new battery, the alternator was replaced with a second hand one, but the problem still exists, regardless of the alternator.
    I took the Aux belt off to try and prove one way or the other that it was the Alternator.
    Another twist and I assume its a bad earth but when I indicate (only when I indicate though) the dash display dims with the indicator
    Sep 2009
    Fife
    Well touch wood lol, I had a voltage drop of around 0.7volts on the cable so I have run another heavy cable (cut up an old jump lead lol) from the Alternator to the Battery (along side the original) and the terminal is still nice and cold. So after a lot of swearing and cursing lol it was the ****** cable all the time.
  1. Tacho output terminal?
    By Caveman_nige in forum Electrical & ICE (including SatNav)
    Last Post: 6th February 2011, 17:13
  2. Terrible noise - is it terminal????? HELP!!!!!
    By chairman_miaow in forum Engine & Drivetrain
    Last Post: 27th September 2010, 20:07
  3. Heating temperature control not working - Full heating permanently
    By jratcliffe3 in forum Electrical & ICE (including SatNav)
    Last Post: 31st January 2010, 23:46
  4. Advert for Cadburys or Terminal 5?
    By AndrewTi in forum Comedy & Humour
    Last Post: 2nd April 2008, 00:03
  5. battery terminal oxidation
    By lakis123 in forum Electrical & ICE (including SatNav)
    Last Post: 13th February 2007, 10:05
