Thread: auto gear box help anyone?
    Nov 2009
    telford
    Default auto gear box help anyone?
    Hi all im still having loads of problems with my auto gearbox, can some please help me! When the car is changing gear it seems to be very jerky! like its changing in the wrong place! also when i slow down suddenly the car feels like its going to stall. Has anyone else had this problem?
    May 2007
    West Yorkshire
    what car, year, mileage and how long have you had it.
    Nov 2009
    telford
    sorry, its a signum elite 2004 and i have had it about 8 months and its done 87k
    Nov 2009
    telford
    Im abit stuck with this one! has no one made this problem?
    May 2007
    West Yorkshire
    hi, the reason I asked how long you have had the car is sometimes the auto's are not as smooth as people expect. I believe the oil levels are critical to smooth running, the stalling issue, not sure maybe torque converter? I would have thought however that both would have been linked. My auto is smooth but sometimes (not often) when slowing and cornering @ the same time the change can be noticeable. May be worth having an auto specialist looking at it and hopefully just an oil change may cure.
    West Yorkshire
    Right, two things you need to do.
    First, if it's not had a fluid change recently, that needs sorting. Makes a big difference. Had mine changed after 26k miles (2.8 V6) and the old fluid was apparently completely knackered. You MUST make sure that you are using the right fluid, if it's an AF40-6 box you need to use proper AW-1 fluid (can get this from Vauxhall), do not use Dextron or anything else, even if whatever it is claims to be compatible.
    Second, you need to find someone with a proper tech2 with security access and get the latest gearbox software flashed. This also makes a big difference.
    Get these things done and it'll be so smooth you will hardly notice the shifts
    Nov 2009
    telford
    cheers for thank stampede will do both of these thanks
    Sep 2010
    belfast
    my vectra c elite 2.2 auto was completely wrecked when i bought ive had it rebuilt but now sometimes when i slow down to walking speed to go over ramps the car will strongly bump into gear can anyone help ive spent a fortune getting the box and the engine rebuilt so my only option is to keep it
    Newport (Shropshire)
    Vehicle : Ford Kuga
    Trim : Titanium
    Engine : 2.0dtci
    Mileage : 1200
    Quote Originally Posted by sshooie View Post
    Inclined to agree, my auto is smooth, no problems, if yours is that bad something's wrong somewhere. Only problem I get is sometimes slowing down at a roundabout or junction if I get back on the power gently it gets caught out and lags a bit - scary, when you roll on to a roundabout, press the loud pedal and nothing happens.
  1. Programming the auto gear box?
    By TopRod in forum Vectra C / Signum Car Chat
    Last Post: 29th January 2010, 11:05
  2. Auto gear changes
    By Alansilverfox in forum Engine & Drivetrain
    Last Post: 13th June 2009, 19:56
  3. Auto gear box only 2nd & 5th pls help!!!
    By watkins1172 in forum Engine & Drivetrain
    Last Post: 12th January 2009, 19:48
  4. Auto Gear Box leaking
    By gregc in forum Engine & Drivetrain
    Last Post: 3rd January 2009, 20:58
  5. Auto upshift on 3rd gear
    By REDMGB in forum Engine & Drivetrain
    Last Post: 13th September 2008, 21:47
