Thread: Oil capacity of Z22YH engine overstated?
    Brighton
    Default Oil capacity of Z22YH engine overstated?
    Stated capacity is 5 ltrs, but seems to be less...?
    Just changed oil + filter on newly acquired 2007 Estate 2.2 Direct. Drained it hottish, including filter chamber. Put in 4.2 ltrs, and expected just above LOW on the stick after running a while. But it's almost on HIGH. Does draining really leave that much in there?
    It was wildly(!) over-full before, 5.7 ltrs drained out! Perhaps previous owner just lobbed in the quoted 5 ltrs plus more for good measure. Being that full might also explain a slight oil leak in the timing cover area?
    Anyone know if the quote "5 ltrs" capacity is overstated, and where on the stick they measure the capacities to?
    Regular Member nibblitz's Avatar
    Jul 2010
    Buckinghamshire
    5 litres went in mine on last service and when warm its half way between min and max marks...
    Im not sure but, I think I read somewhere that it used to be 4.7 to be put in on service schedule, but then it got revised to 5 ..
    Regular Member rushy's Avatar
    Vehicle : SRi
    Engine : Z22SE (2.2 Petrol)
    Mileage : 137000
    No mate I'm sure its 5L, just be sure to only take a dipstick reading no more than 5 mins after the engine has been run. The difference from top and bottom marks on the dipstick is roughly 1L.
    Jun 2006
    Kirkintilloch, Scotland
    5 litres on mine, a 2004 Estate 2.2 Direct, marks the dip stick bang on the max mark.
    Dave
    Brighton
    Default How long is your dipstick?
    Ok, so now... how long is your dipstick?? Anyone able to measure their’s - from shoulder to tip, as the pic?
    I'm wondering if previous owner put the wrong dipstick in. I'm about a litre out, and need to know...
    norn iron
    I find mine only takes about 4.5 litres when doing an oil change, is there not something about a reduced oil level over on z22se.com
    Vehicle : SRi
    Mileage : 137000
    Quote Originally Posted by deg View Post
    That's for the SE mate, the YH takes a bit more.
  1. Z22YH Engine Advice Please
    By rocket999 in forum Engine & Drivetrain
    Last Post: 21st July 2012, 07:47
  2. Z22SE & Z22YH Engine Applications
    By Lean6 in forum Vectra C / Signum Car Chat
    Last Post: 17th February 2012, 23:58
  3. will this fit my z22yh engine..
    By armoured farmer in forum Vectra C / Signum Car Chat
    Last Post: 21st January 2012, 17:23
  4. z22yh engine mounts?
    By Paul_NI in forum Engine & Drivetrain
    Last Post: 5th October 2011, 13:05
oil cupicity z22yh
best oil for a z22yh
swap z 22yh na 22se
what oilfor signum z22yh
vectra 2.2 direct oil capacity
z22yh motor oil
z22yh öljytilavuus
z22yh oil capasity
vauxhall 2.2 engineoil capacity
motor oil z22yh
oil capacity z22yh
z22yh oil capacity
