Thread: HELP losing the will to live cdti 150 juddering
    Aug 2010
    cheshire
    Default HELP losing the will to live cdti 150 juddering
    i have a vectra cdti 150 which has a slight judder when at a constant speed its doing my head in i have changed the fuel filter and put injector cleaner through it i have cleaned the egr valve and cleaned the boost sensor and this morning done the 3rd injector mod but its still the same, tha swirl valves move as they should can anybody help or give me some advice cheers as i am about to get the swan vesta out lol. craig
    Devon
    75 Post(s)
    Vehicle : insignia
    Trim : irmscher
    Have you any EML light on ?
    Irmscher Insignia CDTI 130
    Vehicle : vectra-c
    Trim : sri
    Engine : cdti
    Mileage : 98,000
    Did you completly strip the EGR, the inner plunger gets sticky within the shroud it travels through! marked with the yellow arrow in this pic!, the throttle body would be my next bet.
    Regular Member david.aka.judas's Avatar
    Suffolk
    how about giving it an italian tune up...?
    Vehicle : vectra-c
    Trim : sri
    Engine : cdti
    Mileage : 98,000
    Quote Originally Posted by the-wizard View Post
    http://www.vectra-c.com/forum/showthread.php?t=105853
    Aug 2010
    cheshire
    thanks for your replys i have no eml light onand i have cleaned the egr valve twice i will have another go tomorrow did you say in the pic to lubricare it with wd40 and you also mention the dpf what is this cheers.
    Regular Member crespo's Avatar
    Bournemouth
    maf sensor
    Aug 2010
    cheshire
    i have just done the egr valve as you said and took it out for a run and fingers crossed it has done the trick i will take it for a good run tomorrow see what happens it also seems a bit quicker or is that just me thanks for all the advise. p.s sorry to sound thick but what is the maf sensor and what does it do cheers.
    Bournemouth
    Quote Originally Posted by hitcho View Post
    It is the mass air flow sensor and it controls the intake of air into the fuel combustion. When they are on there way out they cause flat spots (hesitation) usually around 1800 - 2200 rpm espescially on diesels as this is when the turbo spools but can be at other revs. It will feel worse when lightly accelerating through this rev range or when say your sat at 70 in 6th/5th and the revs are at the point where the hesitation is. When i say hesitation i mean it feels like your car is being starved of fuel for a split second.
    You can sometimes get away with giving the MAF a clean with carb cleaner rather than replace it because they are not cheap.
    This may or may not be your problem but if it sounds familier then its worth a look.
  1. 3.o v6 cdti signum losing power
    By s7uby in forum Vectra C / Signum Car Chat
    Last Post: 12th April 2016, 21:19
  2. losing coolant 150 cdti
    By elite_150 in forum Engine & Drivetrain
    Last Post: 25th February 2013, 22:36
  3. 1.9 150 CDTI losing power/boost
    By jay w in forum Engine & Drivetrain
    Last Post: 26th February 2012, 22:57
  4. Juddering in 1.9 CDTi SRi 150
    By stuart-c in forum Engine & Drivetrain
    Last Post: 29th October 2010, 10:37
  5. Losing the will to live....
    By Steve CDTi in forum Vectra C / Signum Car Chat
    Last Post: 29th May 2007, 22:21
