Results 1 to 10 of 13
Thread: Facelift retro fit headlight wash
    Regular Member Keithy's Avatar
    Jan 2008
    Dundee
    Default Facelift retro fit headlight wash
    Has anyone here done a facelift? std sri bumper (not xp2)
    Where do you make the holes? i can't see any markings on the inside of the bumper.
    Pictures appreciated
    Keith
    Dunstable
    You sure it's not on the back of the bumper? My bumper has the area marked out underneath each headlight where the washers go. Had the marks for the parking sensors too
    Jan 2008
    Dundee
    i have just had another look. is it an oddly shaped marking? also... can you see through your grille to the radiator. the one i have got has a panel on the back of it. how does the air get through?
    Dunstable
    The bottom grill you can see through to the rad, the top V grille has a backing plate and you can't see through it. I think the lower grille is a larger opening than on the PF so that lets enough air in. The headlight washers are directly below where the headlights are and should look like a bent rectangle / trapezoid shape, like in the picture below
    Dunstable
    Slightly better pic of them. This is the sort of shape you should see on the back. Mine's only a standard sri bumper and mine has them there, so hopefully your one should too
    Jan 2008
    Dundee
    cheers mate. i only want to fit the washer covers to give it the look. not fussed about them working. do you know how much the stealers charge for them?
    thanks again
    Dunstable
    There was a thread on here with the part numbers etc for each cover. If I can find it, I'll post it on here for you
    Dunstable
    Jan 2008
    Dundee
    cheers mate. i appreciate that
    Wales, UK
    Id like to get these working, doesnt look to difficult. Might be worth doing it when the car is stripped ?
  1. headlight wash system
    By Даниил in forum Electrical & ICE (including SatNav)
    Last Post: 14th March 2016, 10:53
  2. retro fitting headlight washers
    By taffy bhoy in forum Styling
    Last Post: 21st September 2011, 14:10
  3. Retro fit Face-Lift Headlight Washers
    By Meady in forum Electrical & ICE (including SatNav)
    Last Post: 12th May 2011, 13:35
  4. Headlight wash retrofit (facelift)
    By Keithy in forum Vectra C / Signum Car Chat
    Last Post: 2nd October 2010, 10:28
  5. Retro-fitting pre-facelift passenger door switch to facelift
    By greeningr in forum Vectra C / Signum Car Chat
    Last Post: 23rd May 2007, 15:58
