Thread: BMW Z3 2.8 advise pls
    Regular Member wardy's Avatar
    Chichester
    Default BMW Z3 2.8 advise pls
    My dad is thinking of buying one. Found a 1998 2.8 auto. Mileage is lowish at 68k.
    Anything to look out for on these?
    Anyone know when the tining belt is due?
    Full Member Big Sig's Avatar
    No belt as it's a chain. I believe you need to check the rear subframe bushes as it's an expensive job to have then changed.
    Chichester
    Thanks, will do.
    Check here too - http://www.bmwland.co.uk/talker/viewtopic.php?p=175066
    There was a problem with Naskil liners in the engines dropping but I believe that was changed in march 1998. If it has a naskil engine, personally i would avoid it.
    Norwich
    Trim : SXi
    Engine : 2.2
    I think they took the rear suspension from the old E30? You'll be getting about 20mph around town and 25 on a run
    My mate had one and they are heavy on the steering, but apart from that it was relaible and I use to often use it and they are a well made solid car.
    Chichester
    It is a 98 that he is looking at. Well actually I'm looking at it for him tomorrow. Will double check.
    What is Naskil (or from the link Nikasil)?? Forgive my ignorance.
    Quote Originally Posted by the_wave_rider View Post
    Odd, my 328ci was averaging 30 and 36 on a run. mush better on fuel than my gsi was.
    Quote Originally Posted by wardy View Post
    I saw that so I double checked for you. I think it was a material used in the engine manufacture that caused problems. You need to find out if it has one or not and I don't know how to tell although I believe its id'd by a stamp on the engine or something similar. (I probably spelled it incorrectly )
    Just looking to find out how you tell, so far : "I thought there was only one method and that is if there is no tab/plug in the hole above the starter motor its a nikasil"
    See here - http://www.bimmerforums.co.uk/forum/...il-328-t40432/
    Hope ypu can see the thread as its got pics of what to look for
    Chichester
    cheers.
    Looks easy enough to spot, even for a non-mec like me :-)
  1. Advise please
    By Pulja in forum Electrical & ICE (including SatNav)
    Last Post: 28th June 2011, 17:28
  2. Need Some Advise
    By spennny in forum The 'Off Topic' room
    Last Post: 29th March 2011, 13:52
  3. advise please
    By steve66 in forum Vectra C / Signum Car Chat
    Last Post: 5th October 2010, 20:37
  4. Looking for some advise
    By Gortreck in forum Engine & Drivetrain
    Last Post: 17th September 2009, 12:46
  5. New TV , advise please
    By SteveH in forum General Chat
    Last Post: 17th December 2008, 14:03
