Results 1 to 2 of 2
Thread: Correct alternator?
    Northants
    Default Correct alternator?
    Hi again
    Having established the alternator has failed is there any way of establishing the correct output for my model without removing the existing one?
    I'm a mechanical simpleton but know a man that can, thing is I need to have the replacement part waiting for him when he arrives.
    Car is 2007, 56 plate, Signum 1.9tdi (120)
    Also has anyone experience of Vauxcentre? They are quoting £107 (inc) whereas most factors are coming up at £200
    Regular Member LADmachining's Avatar
    Hampshire
    It should be printed on the black end casing, or engraved in the drive end mounting bracket.
    Most will be 100A if you have A/C, but no heated seats etc.
    I would be wary of some of the cheaper (non-genuine) alternators - other forum members report the appearance of new fault codes in the engine ECU once these non-gen alternators are fitted. The standard part communicates with the ECU to control the charge rate, and therefore the load on the engine. Cheaper parts do not do this, leading to the fault codes mentioned.
    If you can live with this, and others have, then the cheaper one will still charge the battery with no problems.
  1. These the correct ones?
    By golfpro in forum Vectra C / Signum Car Chat
    Last Post: 28th December 2012, 03:06
  2. Correct oil for a DTI
    By olid2002 in forum Engine & Drivetrain
    Last Post: 5th February 2011, 23:56
  3. Correct oil?
    By Rebellion8878 in forum Vectra C / Signum Car Chat
    Last Post: 1st February 2011, 10:23
  4. correct oil
    By Dougb in forum Engine & Drivetrain
    Last Post: 27th April 2010, 14:27
  5. have VX used correct oil?
    By wardy in forum Vectra C / Signum Car Chat
    Last Post: 30th April 2007, 20:58
