Thread: Machine polisher
    Regular Member Discreet's Avatar
    Northyorkshire
    Default Machine polisher
    Hi folks
    Can you use a rotary machine polisher to just buff a hand waxed car ?? I am thinking of a Silverline LCD display 1200W 180mm Polisher (240v) or buying a kestrel DAS-6 and slowly building up pads polish ect to eventually be able to properly machine polish a car but it would be nice if I could use the polisher as a buffing tool first. If I cannot it might be worth buying a polishing kit like the ones that autobrite are selling with everything I need advice please ?? and thanks in advance
    Vehicle : Signum 2.0 DTi
    Trim : Elegance/Elite
    Engine : 2.0DTi
    Mileage : 73350
    In a word yes , have a look on www.detailingworld.co.uk for guides on using rotary poisher,s
    Regular Member ANDY W's Avatar
    May 2007
    WINSFORD
    If your after a Silverline I might be able to help out in that area and it has backing plates and pads
    Regular Member messsy's Avatar
    Sep 2010
    Sutton
    Be very carefull with a rotary if you are not experienced bud, they generate a lot of heat if kept in the same spot for a while and will burn the paint, ild go for the das-6 as its dual action
    Regular Member DarylAAS's Avatar
    South Shields
    Yeah DAS6 FTW
    Northyorkshire
    Thanks for the advise guys I have had a look on detailing world at the machine polishing guide's and think I will go for a Dual Action polisher they seam to the best machine for a novice.The DAS-6 does look good value for money as well
    Discreet
    Regular Member R-ford_Vec_C's Avatar
    St Helens
    I bought an Erbauer orbital sander from screwfix for £34.95 + the Meguiars finishing pad + NXT Tech Wax 2.0 from Meg's, works a treat, did the missus' Micra this morning and boy does it look good!!
  1. Machine polisher
    By DNS in forum Detailing and Car Care Discussion
    Last Post: 13th March 2012, 07:24
  2. Machine polisher
    By david.91.09 in forum Detailing and Car Care Discussion
    Last Post: 17th April 2010, 21:58
  3. Machine polisher
    By aerodynamic18 in forum Northern Ireland (RO - Vacant)
    Last Post: 12th May 2009, 22:57
  4. Machine Polisher
    By lizard in forum Detailing and Car Care Discussion
    Last Post: 1st November 2008, 23:00
  5. machine polisher
    By kgsric in forum Detailing and Car Care Discussion
    Last Post: 24th June 2007, 10:56
