Results 1 to 10 of 17
Thread: 1.9 CDTI 120 Help please
    Sep 2010
    sussex
    Default 1.9 CDTI 120 Help please
    Hi i know there are a few posts similar to this but not with all the symptoms?!
    I have a 2004 vectra estate 1.9 cdti 8v I have a few issues that i would be gratefull for some help with!
    Very loud whistling noise from the turbo (not normal turbo noise its reall loud)
    Also it has a loud noise as if air is escaping under pressure
    Poor performance and every 5 min the spanner light comes on going in to limp mode (switch it off and on and its fine)
    It has the fault code P1901 Exhaust gas pressure sensor.
    I have not long had the car and it was not whistling until i found a split in the vacum pipe to the turbo and repaired it now it is much more responsive but has the whistling noise.
    My questions are: Could the previous owner have adjusted the boost to compensate for the split hose and now it is boosting too high?
    Could it be back pressure due to blocked cat etc or turbo ducked?
    Any help would be grate need the car for work!
    Thanks, Marc
    Regular Member winnie2457's Avatar
    kings lynn, norfolk
    If tre is a loud noise still could be a split intercooler pipe or even a cracked exhaust being an estate if there is not enough flow through the dpf and cat in the exhaust system this will give a error code too
    Check all engine boost pipes and intercooler for leaks and check all the exhaust system from turbo back to your dpf in the middle o the car
    Regular Member DaveW555's Avatar
    Cannock
    Would it necessarily have a dpf on a 04 plate? I thought that didn't come in til 05, I may be wrong but just a thought
    Regular Member rec's Avatar
    Jan 2010
    Bradford
    Quote Originally Posted by DaveW555 View Post
    no bud, my 04 plate energy estate has a DPF, ****** thing makes me look like uncle buck as soon as i get on the motorway
    Sep 2010
    sussex
    It def has a dpf i was under the car yesterday! i will try and check all pipes today. The noise sounds like the turbo spinning up but screaching loudly you dont think it could be running too muvh boost? Cheers
    Sep 2010
    sussex
    Hi all i checked all hoses and they are all ok but the intercooler is split so will get a new one there is no play in the turbo so im hoping that it is ok! Would the split in the intercooler cause the loud whistling noise? Anyone got a intercooler?? Thanks
    Jan 2010
    Bradford
    do you mean there is a split in the intercooler Pipe? or the intercooler itself?
    Sep 2010
    sussex
    The intercooler its all out of shape and leaking on both bottom corners but the whistle is coming from the turbo would the intercooler cause the turbo to over spin?
    Sep 2010
    sussex
    Ok i have replaced the intercooler cleaned all the hoses out cleaned the egr and inlet and cleaned out both cats but still whistling!! Took the turbo off today and one of the blades has its tip missing hence the whistle
    I now need a turbo are they different on the 8v and 16v? There are a few 16v ones on ebay but no 8vs Will they fit ok??
    Thanks for your help guys
    Regular Member Marky's Avatar
    Jun 2006
    North West
    Pretty sure they are different.
    This place has a brand new one, for the 8v (Z19DT), on offer at the moment for £400. http://www.vauxhallworldparts.com/pa...e=48&cont=true
    The part for the 16v (Z19DTH) is a different price £700. Which suggests they are different.
  1. Weird noise from Signum CDTI 1.9 CDTI (150)
    By oneightycd in forum Diesel Engine related
    Last Post: 22nd June 2007, 22:27
  2. CDTi 120bhp Vs CDTi 150bp
    By bennyk in forum Diesel Engine related
    Last Post: 6th December 2006, 23:45
  3. CRD2 Tuning Box for V6 CDTi or 1.9 CDTi
    By The Doc in forum Parts for sale
    Last Post: 20th October 2006, 21:51
vauxhall 1.9cdti 120 loud whistle when boosting
cdti p1901 noisy turbo
