Results 1 to 10 of 11
Thread: Slight coolant loss on my V6CDTi
    Regular Member Celes's Avatar
    Slovenia, Koper
    Vehicle : Opel Signum
    Trim : Sport
    Engine : 3.0 CDTI
    Year : 12/03
    Default Slight coolant loss on my V6CDTi
    As above...
    Lost 0.3L of coolant in a month and 5k miles. No excessive pressure in the header tank. The oil is fine and the engine is running better than ever and doesn't smoke...
    No noticeable leaks either
    After I noticed there was a coolant loss I went to Germany and it survived 200miles of 130mph, so I think it can't be anything major...right?
    Full Member Big Sig's Avatar
    Just fill it up and keep an eye on it
    Slovenia, Koper
    Trim : Sport
    Engine : 3.0 CDTI
    Year : 12/03
    Sure hope you're right Sean. Going to Germany again in 10 days
    If its going to drop again then it will do in the next 10 miles imo. (keep a couple of bottles in the back just incase
    Slovenia, Koper
    Trim : Sport
    Engine : 3.0 CDTI
    Year : 12/03
    Topped up yesterday afternoon and it's fine now. A friend with a 9-5 3.0TID suggested it could be a heater valve or something to do with the heater. He's had the same problem on his Saab and when he went to his local Opel dealer in Germany to ask about my problem they couldn't find that part even with my VIN number
    I'll get it inspected when I book it in for valve readjustment €€€€€€€€€€€€€€€€€€€€€€€€
    EVERYWHERE
    Quote Originally Posted by Celes View Post
    Winston Churchill spent all of our money on Singapore instead of building us an autobahn network.
    Hope those 'liners' are holding up OK?!
    Oct 2009
    portland
    Vehicle : Bmw 330d
    Trim : Msport
    Engine : 3.0d
    good luck. fix itself
    Mine also lost some coolant, then it suddenly stopped a few days later
    When topping up I used 50:50 coolant, rechecking the gravity afterwards
    It was slightly weak so I removed a litre and replaced it with 100% coolant, returning the gravity back to the correct level
    Slovenia, Koper
    Trim : Sport
    Engine : 3.0 CDTI
    Year : 12/03
    Quote Originally Posted by diesel dog View Post
    Gotta love Germany Everyone should try out the A92 at night. Mόnchen-Deggendorf
    If there was a liner issue I THINK I would have a lot of pressure in the expansion tank. But seeing as I only have a little I think the engine itself is in good shape. No white smoke or oil/coolant contamination.
    blackwood
    have a look at the front of the front cyl head, timing belt side, where it joins the engine block, cyl head gasket on mine had gone there, small coolant loss at first and it was collecting in part of the engine block casing and boiling off, so could'nt find the leak at first, did in the end when the gasket was totally blown.
  1. slight Loss of power 1.9 cdti 2006
    By leedrummond in forum Engine & Drivetrain
    Last Post: 12th May 2012, 14:08
  2. CDTI 150 slight coolant loss
    By AntSSSS in forum Vectra C / Signum Troubleshooting
    Last Post: 19th July 2011, 21:34
  3. V6CDTi coolant loss - heater bypass valve?
    By Celes in forum Engine & Drivetrain
    Last Post: 6th October 2010, 17:50
  4. Coolant loss
    By monkeyhinger in forum Vectra C / Signum Car Chat
    Last Post: 26th July 2009, 23:42
  5. Spanner light and slight loss of power 2.2dti
    By nickd_m in forum Engine & Drivetrain
    Last Post: 10th November 2008, 23:28
