Results 1 to 10 of 13
Thread: dimming..
    Regular Member kenp's Avatar
    Kr. Hyllinge, Denmark
    Engine : 2.2 Direct
    Default dimming..
    Hi Guys
    just thinkign driving home last night.. (after been out running 3,5 miles with 25.000 other people)
    That my light switch didnt change the light in the buttons even when i used the knob that should change how much light there should be!!
    I cant remember how it should be..
    also there was no light in the little knob that you actually use to ajust the dashlight..
    And also it didnt change the light in my "indirect" night lightning.. i think to recall that my last interiur mirror did change the indirect light.. when playing with it...
    anyone that can tell me...
    WGAF#5
    afternoon Ken,
    the Knob should be illuminated and the indirect night light doesnt change as far as i can remember
    Engine : 2.2 Direct
    Okay.
    Then that "led" is gone.. (ill maby change that)
    but the other buttons on the light swich should they change... when playing with the dimming of the dashs ect... because it dont..
    maby i should change it.. but if its not i fault... then its wasted money..
    Engine : 2.2 Direct
    hummm noticed something else.. when i open the doors.. nearly everything lights up.. but not the lightswitch (and the switches on it....)
    Normal.. or have i just not noticed for the past 4 years....
    Regular Member Keithy's Avatar
    Jan 2008
    Dundee
    the led on the mirror does not come on with the lights, it actually comes on when it is dark. there is a sensor on the mirror that controls it
    Engine : 2.2 Direct
    Quote Originally Posted by Keithy View Post
    I do know that.. but you can ajust the lights in the dash.. i just couldt remember if that also made the one in the mirror more dim or brigth.
    Dunstable
    I believe the switch leds illuminate all the time when the ignition is on only. When you unlock the doors, it shouldn't illuminate, also when you turn your lights on with the ignition off it shouldn't illuminate, only when the ignition is on does it light up, hth
    Engine : 2.2 Direct
    now just to clearify if the dimmer button also dims the illumination on the lightswich
    Dunstable
    No it shouldn't do, it's on a "different" circuit to the rest of the dashboard buttons, as I said, it only comes on with the ignition. I think the idea is, if you dim the interior illumination it won't dim the light switch illumination as you need to be able to see it clearly at night without fumbling around for it
    Engine : 2.2 Direct
    I learn something every day only had the Vec for 4 years now
  1. dimming mirror
    By woody in shetland in forum Vectra C / Signum Car Chat
    Last Post: 9th December 2012, 01:38
  2. Led into the dimming mirror
    Last Post: 21st February 2012, 13:46
  3. Lights dimming
    By micks edition 100 in forum Electrical & ICE (including SatNav)
    Last Post: 12th January 2010, 23:25
  4. Dimming mirrors...
    By Russi666 in forum Bodywork & Interior
    Last Post: 27th September 2008, 19:59
