Results 1 to 10 of 22
Thread: MPG decrease after adding 19's
    Liverpool
    Default MPG decrease after adding 19's
    just wondered if anyone else has noticed
    After having my first full tank burnt off after adding my 19's, i have notced i have only got 580 miles from a tank
    with my standard 17's on, i was getting around 650-700
    anyone else had this? it may be the fact that i still havent got the tyre pressure right
    Jul 2006
    liverpool
    Have you had your speedo recalibrated? You probably have to get it done via Tech 2.
    An extra 2 inches on your wheels will affect your speedo reading and also your calculated MPG. As your wheels are bigger they will take longer to do a full rotation and so your mileometre will also be out. If ive got this right... Your car will "appear" to be doing less miles as a result. Your actual MPG wont be that different i wouldn't have thought though.
    Hope this helps.
    Apr 2009
    Quote Originally Posted by riverdees View Post
    Hope this helps.
    The wheels are bigger yes, but the rolling road circumferrance of the tyres is the same as before. The profile size of the tyre should only now be 35mm to compensate for the bigger rims.
    May 2006
    scotland
    As he said above. I consulted my wife and she said an extra 2 inches makes no difference at all. She is an expert in this area (an engineer :-).
    Ok - the rolling radius of the wheel/tyre combo is ALMOST the same. There are calculators online that will tell you the exact differnce but it should only be a few mm at most, which is no different to having worn down your tyres.
    Differences could be caused by the wheels being slightly heavier, bad fuel in the tank, or a million other things. See if it gets any better after a few tanks as that may have jsut been a random coincidence...
    Also, the profile of the tyre is 35% of the tyre width, not 35mm...
    Oct 2006
    Waterloo, Liverpool
    12 Post(s)
    Trim : SRI NAV XP
    Engine : 1.9 CDTI 150
    Mileage : 72K
    Quote Originally Posted by paul_sri150 View Post
    Under inflated tyres will not help at all. And it won't do the tyres any favours either. 39/35 front/rear is what the manual says. Don't be tempted to lower pressures to soften the ride.....it doesn't.
    The twice plus two 'rule' is a good guide IMO........at least for the fronts.
    After a little bit of experimentation I'm running 41/38 front/rear and it feels just fine for me.
    I went from a 2.0T on 17"s to an SRI CDTI 150 with 19"s, and I'm getting a minimum of 550 per tank, as opposed to 350 with the petrol, which is about right for my driving mix.
    Aug 2010
    Antrim
    I can tell you how, but I have often read in car magazines that larger wheels equals both poorer ride quality and poorer fuel efficiency. I can understand the ride issue, but unless the tyres are wider on the bigger diameter wheel, I am at a loss to explain the loss in fuel efficiency.
    Oct 2006
    Waterloo, Liverpool
    12 Post(s)
    Trim : SRI NAV XP
    Mileage : 72K
    The difference in fuel economy as with CO2 emissions will be minimal. But as said under-inflated tyres will cause more of a difference.
    Regular Member MalcGSI's Avatar
    E Sussex & Kent
    Quote Originally Posted by WilliamLX View Post
    well 235/35/19 is wider than 215/50/17
    Regular Member stormspiel's Avatar
    Jul 2010
    Wakefield
    215/50/17 vs 235/35/19 gives a 0.05% difference which is 0.3mm in diameter and a 0.94mm difference in circumference. not enough to mechanically throw it out out of kilter.
    The main thing that'll impact the MPG is the rolling resistance. Whether it's properly inflated or not there's an extra 20mm x 100mm (100mm approx for distortion on contact with road) patch on each tyre in contact with the road.
    More contact means more resistance therefore more juice required to keep pushing you along.
  1. Adding Aux
    By Ginge7289 in forum Electrical & ICE (including SatNav)
    Last Post: 29th March 2011, 10:52
  2. Adding DAB
    By Blue Thunder in forum Electrical & ICE (including SatNav)
    Last Post: 19th October 2008, 21:57
  3. Do these mod boxes decrease full economy
    By rollercoaster63 in forum Diesel Engine related
    Last Post: 6th December 2007, 03:16
  4. Adding Sub and Amp
    By Adamant in forum Vectra C / Signum Car Chat
    Last Post: 30th April 2006, 00:34
