Results 1 to 10 of 11
Thread: Signum Towbar
    Fife
    Default Signum Towbar
    Following my last thread about towing with a Signum (and thanks for all the Good news) I now need to get a towbar fitted. Vauxhall quoted £515(yikes!), my local indespension dealer £380(for detachable Brink).
    Seems like you have to cut the bumper for the detachable towbar...or does anyone know different?
    I'd appreciate any help.
    Derek
    Regular Member gizmo10119's Avatar
    Cambridgeshire
    hi matey
    i had a vectra hatch with a towsure eclipse towbar, i have never had a problem with it and am about to fit it to my vectra estate check out thier website www.towsure.co.uk they are priced reasonably and are easy to diy fit.
    I didnt have to cut my bumper
    Leicester
    I bought the complete detachable Vauxhall towbar with 12N and 12S electrics for £296 inc VAT, fitted it myself which took only 2.5 hours.
    The instructions do state to cut the bumper but you don't actually need to, it was the same with my Zafira GSi, stated to cut it but you don;t need to.
    As far as I aware, on the genuine Vauxhall kit for the Signum you don;t need to cut anything.
    Regular Member Gripper's Avatar
    Middle Wallop Andover
    Hi there. Reading these threads with interest as I want to fit a tow bar to my car. If I buy the one you have reccomended from TOWSURE do I have to go to Vx and pay through the nose for them to do the tech 2 mallarky so that it will work.
    Leicester
    Quote Originally Posted by Gripper
    It all depends on how well you get on with your dealer. They did'nt charge me to do my Vectra, and when we needed to do my dads new Zafira, I went down there and used tech 2 and did it myself.
    But in answer to your question, if you use the proper plug in electrics you will need to programme the car.
    Fife
    Hi,
    Excuse me for asking but what is this 'tech 2 malarky'. Any towbars I have had fitted in the past just tap in to existing wires - does the signum have some special connector or something which means the electronics need re-programmed or something? My omega had a really annoying bleeper in then boot, which you couldn't always hear if the boot was full - does the signum have have something in the dash which tells you if the inidcators are working.
    Excuse my lack of car tech knowledge but I just usually take the car to the garage when anything needs done!
    Derek
    Regular Member marichrd's Avatar
    Jun 2006
    Cheshire
    the Tech 2 is the programming unit and diagnostic tool used by the dealers.
    When you have a towbar fitted on these Vectra C and Signum, you typically need an 'electrics box' which connects into the rear fuse box. The towing functionality then needs to be activated in the Electonics control modules.
    Feb 2006
    Dorset
    All the rear lights of the vectras and signums use Can-bus (Controlled Area Network-Bus), so if you tapped into it the control unit will have a hissy fit , modern cars really are a pain to work on as most ingnition controlled systems are now done with the can-bus
    Regular Member ukanalyst's Avatar
    Jul 2006
    Cheshire
    Quote Originally Posted by decho
    Hi,
    The Vectra has one of these too ... it's called the alarm!
    Leicester
    Fortunatly, the genuine Vauxhall electrics for Vectra C, Signum and Zafira A & B do not have the bleeper, thank god!!!
  1. Help with Signum towbar
    By MARTIN FROM LLAN in forum Vectra C / Signum Car Chat
    Last Post: 7th November 2012, 08:23
  2. towbar for a signum..?
    By signum driver in forum Vectra C / Signum Car Chat
    Last Post: 7th October 2011, 16:00
  3. signum towbar
    By cih176 in forum Vectra C / Signum Car Chat
    Last Post: 11th March 2007, 19:47
