Results 1 to 10 of 21
Thread: Damn it!!
    Regular Member Ben_'s Avatar
    Audiville, WM
    Default Damn it!!
    Picked up some new SRI wheels at the weekend (cheers Ian) to finally replace my horrid SXI ones.
    Thought i might as well paint calipers (decided on red) at the same time, all was going well had one side done, came to taking the last wheel off and the locking nut key snapped!!! so now had to put old wheels back on so car can be taken somewhere to get the locking nut removed.
    I know this seems to be a reoccuring theme at the moment with locking keys / nut........some solutions a bit to drastic for my liking!
    Is the best bet to take it to Cresser and just get them to loosen it, and replace with a standard bolt, don't want to wait around for new key.
    Or would any hi-q etc be able to sort it??
    and this only hours after signing up as full member.........have i been cursed
    Liverpool
    DONT hammer a socket over it, happend to me, your best bet is either a locking wheel nut remover, or just wait for your replacement key from VX
    i ended loosing a decent wheel through this , had to be angle grinded off
    Audiville, WM
    i saw mate thats the drastic solution i dont want to take
    Vehicle : Signum 2.0 DTi
    Trim : Elegance/Elite
    Engine : 2.0DTi
    Mileage : 73350
    Take your car to your main vx dealer they should have a set of master keys
    Jul 2010
    Telford
    Quote Originally Posted by bobssignum View Post
    only if the car is after a certain year which i believe is 05
    they dont hold masters for older ones , i tried
    Engine : 2.0DTi
    Mileage : 73350
    They do at mine because i have done it.
    Failing that if you know your key no ,see if there is anyone local to you on here with the same key .
    Regular Member rushy's Avatar
    Vehicle : 9-3 Wagon
    Trim : Turbo Edition
    Engine : TID (1.9 16v)
    Year : 2010
    Mileage : 137000
    When you say snapped do you mean the key part has bent, so it just pushes off when you turn it? If so then park the car next to a wall and jack the key onto the nut with a tyre iron.
    Sodding Typical on Sea
    Hmmm,,,,,,,,, so you've had to do this too eh?? Annoying as heck ain't it! Hate locking wheelnuts with a vengence I do
    Regular Member Vaux-Man-G's Avatar
    Birmingham
    Something that has always worked for me is to spot weld a normal bold onto the head of the lock bolt. You get a tiny burn on the inside of nut hole but its cheap and easy to get rid of the horrid lock nuts that Vx supply uou with. I usually take it to a local garage. This has happened to me a few times on a few different cars. I also usually find that when I damage the lock nut key, I have usually caused some damage to bolt head aswell, so best solution for me.
  1. Damn i need both of these.....
    By signum_rob in forum General Motoring Chat
    Last Post: 25th June 2012, 08:20
  2. god damn it!!
    By dahmich in forum Vectra C / Signum Car Chat
    Last Post: 12th March 2012, 10:59
  3. Damn car!
    By geebee007 in forum Suspension, Wheels & Brakes
    Last Post: 17th May 2011, 23:05
  4. Dry damn you dry!
    By nutron in forum Vectra C / Signum Car Chat
    Last Post: 14th April 2007, 01:26
  5. Damn PVS........
    By The Doc in forum Vectra C / Signum Car Chat
    Last Post: 15th May 2006, 17:48
