Thread: using wax ?????
    Regular Member shillbag's Avatar
    Apr 2006
    Leicester
    Default using wax ?????
    my signum has near perfect paintwork but i have noticed some swirls have appeared on my bonnet. i have seen a few threads saying that i should use clay. can someone tell me about it and how to use it. can i get it from halfrauds ? when in the cleaning/polishing/waxing process should it be used ?
    any info will be gratefuuly received as i like to see the siggy in perfect order
    Regular Member Harry's Avatar
    Uxbridge, London
    claying should be done directly after you've washed and dried the car. it comes before any product you wish to use on the car.
    the clay may well reduce the swirls but its main function is to removed any stuck on road grime and dirt.
    the best way to get the swirls out is to polish them out, hand polishing will not get you the results your after - you'll really need a porter cable to get the best finish possible. this is what i'm currently thinking about investing in after a demo.
    more information about getting the best finish for your car on www.detailingworld.com
    porter cable information can be found on http://www.autopia-carcare.com/how-to.html along with a whole library of cleaning etc.
    the clay can be bought from halfords and comes with a bottle which you use as a lubricant - it cost around 12 quid if they have it in stock.
    do a site search on "clay bar" and you should come across the How 2 and various other tips and advice
    Apr 2006
    Leicester
    cheers harry thanks for the excellent advice
    Regular Member rushy's Avatar
    Vehicle : 9-3 Wagon
    Trim : Turbo Edition
    Engine : TID (1.9 16v)
    Year : 2010
    Mileage : 137000
    Get ready to sweat! A lot of hard work there mate but the results will blow you away. You think your paint is clean?! You want to see what the clay pics up! Just doing the bonnet on my star silver turned the clay brown!
    Apr 2006
    Leicester
    how long for the full treatment. is there anything i need to watch out for mate ?
    Vehicle : 9-3 Wagon
    Year : 2010
    Mileage : 137000
    If you drop the bar bin it! Use plenty of lub, Keep it warm so it molds better, always check the surface of the clay for dirt as that will scratch your paint. Start at the top of your car and work down, roof, bonnet, top of doors and so on.
    The megs quik clay from halfords is perfect for a first timer and will do the hole car, just!
    Oh yes, when the clay get dirty fold it once in half and turn it one quarter in your palm.
    Vehicle : 9-3 Wagon
    Year : 2010
    Mileage : 137000
    Quote Originally Posted by shillbag
    Not as long as you think mate. Before you do it wash and dry the car and run your fingers over the bonnet and you will feel tiny imperfections, when you have done it will feel like glass! Warning, this will strip all protection of paint, as in wax, so to do the full job you'll have to wax at least as well.
    You might as well go the full hog an polish it as well.
    Your avitar looks star silver if so try megs tec wax, its done a cracking job on mine.
    With all these extra stages the time does add up though mate, so you best put 3 hours to one side.
    Apr 2006
    Leicester
    time is not a problem. if it takes that long for perfection, so be it.
    you are right, it will be my first time so i need to take precautions
    Vehicle : 9-3 Wagon
    Year : 2010
    Mileage : 137000
    Dont forget the pics!
    Apr 2006
    Leicester
    how could i forget
    IT'S THE LAW.
