Thread: 2.2dti misfire
    Regular Member Keithy's Avatar
    Jan 2008
    Dundee
    Default 2.2dti misfire
    anyone had a misfire with the dti engine?
    noticed for first five mins when started from cold i'm getting a slight misfire when idling. goes away once heated up.
    Don't think it will be glow plugs as it hasn't been cold enough to fire them up
    thanks
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    Air in the pipes? When were the leak off pipes done and did you fit a new rubber seal when you changed the diesel filter?
    Regular Member Innes's Avatar
    Plymouth
    Question for John - I've heard about the leak-off pipes before but dont know what they are and where they are. are they something that should be replaced/cleaned often?
    Regular Member zafira's Avatar
    Aug 2010
    North of Norway
    I had the same problem on my last opel omega dti when the pipes to the inlet manifoild was broken. Check pipes. Another ting, I am not shure, but doesnt the glow plug start when its warm outside when ignition turns on, but lamp inside dont come on because its glowing so fast? Anyone?
    Regular Member Celes's Avatar
    Slovenia, Koper
    Vehicle : Opel Signum
    Trim : Sport
    Engine : 3.0 CDTI
    Year : 12/03
    I'm getting sort of a miss when I rev the engine up to 1700rpm...what could that be? Starts fine and runs OK though. Powers is there when I need it and it doesn't smoke.
    Regular Member si_hoss's Avatar
    Apr 2009
    Stevenage, Herts
    Quote Originally Posted by Innes View Post
    Innes - see this thread http://www.vectra-c.com/forum/showthread.php?t=59573
    Oddly I changed mine last weekend after putting it off for a year!! I can't leave it parked uphill over night or it won't start. Also recently the first start of the day or left outside work for 8 hours it has to turn over a good few seconds then splutters into life. After changing these pipes, made no difference to starting. Yet to test the uphill over night issue but too scared to lol.
    Was actually a real easy job, only thing I found was to gain room remove the EGR (so time it with cleaning that) to get to the lower (pump) pipe, and remove the elbow above that where the boost sensor lives (and clean that out too). Remember as a MUST to use washing up liquid to lube up the t-pieces etc so the pipes go back on. I badly bent the first t-piece cos I tried pushing it on dry, so need to go back and by one more and change.
    The pipes I took off have a date stamp of Feb '02!! My new ones purchased last year say Mar 09 Give it a go!
    Slovenia, Koper
    Trim : Sport
    Engine : 3.0 CDTI
    Year : 12/03
    The cause for poor starting when parked facing uphill is the injector seals. My mate had problems with his Vec DTI for 4 years and when they finally replaced the injector seals the problems went away.
    Forfar, Scotland
    Trim : LE/VXR
    Year : 13/07
    Quote Originally Posted by zafira View Post
    You are correct, they always come on, just not so hot in the summer. Glowplugs wouldn't cause a misfire under idle as they are only used to start the car
    Apr 2009
    Stevenage, Herts
    Quote Originally Posted by Celes View Post
    I had the injector seals replaced when I got it for this issue, only 24k ago and it's always been a problem. I found parking downhill cured it...
    Jan 2008
    Dundee
    yeah, i fitted new seals but did notice some stains around inj no 1.
    its not a prob. only indication i get is a slight vibration when idle for the first five mins. no smoke and car pulls well
  1. 3.2 misfire
    By noudder72 in forum Engine & Drivetrain
    Last Post: 29th November 2011, 23:05
  2. Misfire on 2.2dti
    By hendrix in forum Engine & Drivetrain
    Last Post: 11th August 2011, 19:29
  3. low rev misfire
    By super sleuth in forum Engine & Drivetrain
    Last Post: 9th April 2011, 20:56
  4. misfire?
    By ivesy in forum Engine & Drivetrain
    Last Post: 11th February 2011, 19:55
  5. V6 misfire?
    By lencuff in forum Engine & Drivetrain
    Last Post: 16th November 2010, 21:10
vectra 2.2 misfire dti
vauxhall vectra dti missfire when cold
zafira dti misfire
2.2 dti misfire smoke
