Thread: LED sidelights fitted (Pics)
    Engine : 1.9 CDTi
    Default LED sidelights fitted (Pics)
    Just finished fitting my LED sidelights and have the normal strobing now and again and when I turn the off so going to piggy back the originals.
    The LED's I went for are these (As you can see there are plentyof LED's to light up the reflector):
    And this is how bright hey are lol:
    And the light the car in front :
    Regular Member hairy31's Avatar
    Jun 2009
    bradford
    looks good mate..........let the strobeing commence..........lol
    Hanging Heaton / Batley
    19 Post(s)
    Trim : SRi (VXR Styling)
    Engine : Z19DTH (Re-mapped)
    Mileage : 110k
    Just been looking at LED lights on ebay, these will be brighter then the standard dipped beam lol
    Engine : 1.9 CDTi
    Piggyback some normal bulbs on the wire wires over the weekend.
    Thinking about getting an under bonnet light that I could wire the orignal bulb wires into so I can check my levels at night if I need to.
    If your looking for LED's make sure they point sideways onto the reflector as the others are rubbish.
    These were only £6 each: http://www.ultraleds.co.uk/501194t10...al-p-2191.html
    19 Post(s)
    Mileage : 110k
    I prefer the normal 501's but with inverted tips, i like the dull white/blue glow to be honest... Already got mine hard wired in...
    Like the under bonnet light idea myself, i've taken the under bonnet heat shield off mine and you get 4 holes in the 2 centre bonnet supports. I'm fitting 4 flush fit side repeaters in there and having an alarm sensor switch to earth it all... Will only come on then with the bonnet open...
    Under bonnet needs spraying 1st so i've just been collecting bits
    Regular Member eaglepva's Avatar
    Up North
    nice and bright m8
    Regular Member Steven T Davies-Moss's Avatar
    shropshire
    do they fit in easy as they are bigger than the original bulbs... im looking at these ....
    http://cgi.ebay.co.uk/2X-25-SMD-LED-...item3360875a5e
    SCOTLAND
    would these work without warnings or strobing? need a new number plate bulb and was going to use my mtec 501 sidelights in number plate and try led's for front sidelights
    http://cgi.ebay.co.uk/ws/eBayISAPI.d...=STRK:MEWAX:IT
    Engine : 1.9 CDTi
    The first link looks like the ones I have and the second one looks like they should be ok as they will still draw 5watts like bulbs.
  1. Running LED sidelights/fogs - No Errors... lots of pics
    By Leemarksmith in forum Electrical & ICE (including SatNav)
    Last Post: 14th June 2012, 20:59
  2. Got bored, fitted LED sidelights!
    By Birchy63 in forum Vectra C / Signum Car Chat
    Last Post: 12th June 2010, 17:57
  3. Hids / Sidelights fitted :O)
    By DazzaVec in forum Vectra C / Signum Car Chat
    Last Post: 2nd April 2010, 12:19
  4. Now fitted Led sidelights and de-baged boot
    By damoore1983 in forum Styling
    Last Post: 19th June 2009, 20:12
  5. Looking pics of a Double din fitted?
    By Rik N.I. in forum Electrical & ICE (including SatNav)
    Last Post: 4th April 2008, 16:02
