View Poll Results: can secondhand flipkeys be re-programmed?
Voters
29. You may not vote on this poll
  • Yes
    15 51.72%
  • No
    14 48.28%
Page 1 of 4 123 ... LastLast
Results 1 to 10 of 34
Thread: flip key
    Regular Member chris1804's Avatar
    Oct 2009
    Sandwell
    Default flip key
    i know this has been asked before and ive search on here and some people say yes and some say no, can secondhand flipkeys be re-programmed?
    Halstead, Essex
    I would really want to know this as well. I bought one a few weeks on e-bay...got the blade cut by key code...but VX dealer told me that it going to cost 40 pounds for programming even if it's going to work even if it won't.
    Birmingham
    Thats a definate NO! I have had this tried by two different Vauxhall people, back door jobs, and both have advised that second hand flip keys cannot be done! Its annoying cos I wanted one done!
    Bye bye Vec B
    - Hello Siggy!
    Regular Member Innes's Avatar
    Plymouth
    No because the information can be only written to the transponder on the key once. The transponder is part of the chip board. On the older Vauxhalls the transponder was seperate and all you had to do was buy a new blank transponder and code that. Just done my mate Vectra-B that way.
    Halstead, Essex
    Unless you can find a blank transponder right innes?
    north east
    Ok odd question, My spare (was the original) key case is damaged, I was thinking of just buying another key and swapping the internals and blade over does this mean you cant do that anymore ?
    Halstead, Essex
    On the contrary roswell...if only the plastic cover is damaged you can buy an empty shell of ebay. It will work great for you...but not for us
    Plymouth
    i've only seen blank transponders for the older vauxhalls. The flip key codes as one unit in one process. Coding the vectra-b was a two stage process. Transponder then remote key fob.
    Halstead, Essex
    So the only option is 120 pounds at VX stealers? Damn
    Plymouth
    no. About £25. You can buy a blank key off ebay for £15 and a new cut blade for £10. You can then code the key yourself if you have a certain bit of software that we arent allowed to talk about on this forum.
  1. flip key
    By Swedge in forum Electrical & ICE (including SatNav)
    Last Post: 3rd February 2013, 16:11
  2. New flip key
    By gibbon7000 in forum Vectra C / Signum Car Chat
    Last Post: 1st January 2012, 11:07
  3. 3 button non flip key internals fit straight into a flip key shell???
    By Jow20 in forum Electrical & ICE (including SatNav)
    Last Post: 25th November 2011, 01:44
  4. Flip Key has lost it's flip?
    By maurauth in forum Vectra C / Signum Car Chat
    Last Post: 20th April 2010, 12:23
  5. Old Key to flip key
    By CBag7 in forum Electrical & ICE (including SatNav)
    Last Post: 7th May 2009, 14:08
