Results 1 to 2 of 2
Thread: Help how do i check my auto gear box level?
    Nov 2009
    telford
    Default Help how do i check my auto gear box level?
    Hi all, Im after a dummys guide on how to check my gear box oil level. I have a 2.2 auto signum 2004. If some one has pictures or a step by step guide to help me i would be very grateful.
    Jul 2009
    barnsley,yorkshire,GB
    Engine : 20 Dti
    Hi Luke
    transmission fluid needs to be running temp,vehicle on level ground,remove upper engine cover put shift control from P to D and back to P with engine idling and hand brake on.unscew bolt from transmission dip stick and remove O ring from dip stick.replace dipstick for 2 or 3 second (engine still idling)check oil level on stick ,it should be between grooves of hot mark,top up if needed. DO NOT REMOVE LARGE HEXAGON SEALED BOLT OTHERWISE TRANSMISSION WILL NEED REPLACING.
    top up between Min and Max is about 0.3 Litres.don't forget to refit O ring when finished,job done easyyyyyyyyyyyyyy
  1. How do I check the DPF saturation level?
    By inchy1981 in forum Vectra C / Signum Car Chat
    Last Post: 23rd November 2012, 22:42
  2. This is why you should check oil level
    By Critch in forum The 'Off Topic' room
    Last Post: 11th October 2012, 12:53
  3. clutch fluid level? how do i check it?
    By renton608 in forum Engine & Drivetrain
    Last Post: 8th February 2011, 19:25
  4. How to check oil level on 3.0 Diesel Auto box
    By NPS in forum Engine & Drivetrain
    Last Post: 20th April 2010, 07:46
  5. Best Time To Check Oil Level?
    By Avenged in forum Engine & Drivetrain
    Last Post: 25th January 2009, 21:38
