Thread: Wheel Bearing?
    Aug 2010
    Dublin
    confused Wheel Bearing?
    Hi All,
    I have a 2005 Vectra C 1.6 petrol I've had an ongoing problem with my steering shuddering at speeds over 80 kph and a droning noise from the front passenger side wheel area. I have balanced all 4 wheels and even switched the front wheels to the back and vice versa with no improvement. I dont have low profile tyres and the noise is getting louder.
    I have a feeling its the bearing am I on the right track?
    Any feedback would be appreciated.
    Regular Member Keithy's Avatar
    Jan 2008
    Dundee
    wheel brg would cause noise. shuddering could be gearbox mounting
    Aug 2010
    Dublin
    Thanks for the reply. The steering wheel shuddering is like what you would experience with an unbalanced wheel the engine and gear box feel smooth. Would the bearing cause the steering to shudder at higher speeds?
    Jan 2008
    Dundee
    i wouldn't think so unless it was severely worn. in which case i wouldn't drive it
    Aug 2010
    Dublin
    This has been going on a while what are the side affects of driving with a severly worn bearing ?
    Jan 2008
    Dundee
    in some cases it can collapse and sheer the hub, then your wheel falls off. best get it checked. new brg about 90quid. easy job if you have the tools
    Aug 2010
    Dublin
    Exclamation
    Thanks mate I will have checked ASAP!
  1. UJ or wheel bearing?
    By Endricks in forum Engine & Drivetrain
    Last Post: 8th April 2012, 10:49
  2. Wheel Bearing ?
    By jer75 in forum Suspension, Wheels & Brakes
    Last Post: 30th August 2011, 02:01
  3. wheel bearing
    By stuart bigboy in forum Suspension, Wheels & Brakes
    Last Post: 28th October 2007, 17:07
  4. Wheel Bearing with VX?
    Last Post: 6th March 2007, 00:19
