Page 1 of 5 123 ... LastLast
Results 1 to 10 of 48
Thread: dti intercooler pipe
    birmingham
    Default dti intercooler pipe
    Hi all
    Got a cut about 5inches long in the top hose to turbo. This was causing EML to come on and enter limp mode.
    went to vauxhall who want £90 for the hose and includes the metal tubing that sits on the top of the rocket cover
    is there anywhere else i can get one from cheaper, or somehow repair the hose?
    Hertfordshire
    I wouldn't try a repair m8, only on a temporary basis, the hose is too stressed to have a repair done and last long term.
    Something is wrong there though, you don't need to change the metal tube, which is a separate part, you just want the rubber one.
    Mine was changed under warranty by Vx when mine split, so I am sure it is available on it's own, I would not expect it to be much above £20-£30 at the most.
    You can not buy an aftermarket direct replacement.
    But you could make one up with a couple of different Samco hoses for example, probably gona coat around £50-£60 or so though, but will be much, much better quality, and will last the life of the car.
    birmingham
    Quote Originally Posted by Green Growler
    anyone got the part number for the hose?
    Hertfordshire
    I'm afraid I haven't m8, it was a warranty job, and I never saw any paperwork for it.
    Feb 2006
    Guttedsville
    Look on another thread here, Tony got his for £75. fits in 10 mins! He should be able to give you the part no' too.
    Thornton-Cleveleys
    Hi b21, I talked to the local dealer and asked them to check that you cannot just get the hose but apparantly vx changed it a while ago so that you can only buy the whole lot including the aluminium pipe that goes down behind the radiator. I just took the hose off the top and fitted that. The part no. is 93185363 I was qoute £76 + vat but got some discount.
    Hertfordshire
    That's a rip off, you SHOULD be able to get them separately, I don't think the whole lot was changed on mine, but that's not to say the parts didn't all come as one.
    Personally, for that money, I would NOT waste it on Vx parts, I'd make a Samco hose up, much better quality, and cheaper !!!
    birmingham
    well vauxhall say they replace the single pipe on warranty work nd throw rest away - yeah right
    ROCHESTER
    UPDATE ON PRICE from vx dealers. they now want 160 quid for the hoses. wont split as i only need the rubber bit. had all same faults as everyone else. but i changed my mas air sensor first then hose split. both causing spanner and limp mode when when power needed. think ebay going to be used
    Nottinghamshire
  1. Should these fit over my intercooler pipe?
    By Alank in forum Vectra C / Signum Car Chat
    Last Post: 2nd June 2011, 18:00
  2. is this an intercooler pipe?
    By richje100 in forum Engine & Drivetrain
    Last Post: 25th February 2011, 06:11
  3. intercooler pipe
    By tigertye in forum Engine & Drivetrain
    Last Post: 3rd October 2010, 12:29
  4. intercooler pipe
    By sarahds in forum Engine & Drivetrain
    Last Post: 5th October 2009, 14:07
  5. Intercooler Pipe, HELP!
    By joewin1975 in forum Engine & Drivetrain
    Last Post: 22nd October 2008, 21:02
