Results 1 to 10 of 16
Thread: Twin exaust conversion
    norwich
    Default Twin exaust conversion
    Hi all, After 4 weeks of trying to sell my Signum, I've conceded defeat and decided to keep it. Now I want to get it looking the way I want. I have a 2.2 direct with the twin exausts hidden underneath. 1st thing I want to do is to get these so they are visible. Can anyone advise me what I need to do and where to start. Cheers Ian.
    Regular Member Jezzy's Avatar
    S.E
    The grey trim under the bumper that hides the exhaust - get a replacement for that from Vauxhall that has two cut outs in it that allow the exhaust pipe to exit through them. If you want, you can also colour-code this trim. Then cut off the down-turned tips on your existing back boxes and bolt on a pair of stainless steel tailpipe tips/extensions. Sorted.
    norwich
    wow as easy as that. I was expecting to have to weld some pipe on. the piece I have to take off my bumper,how is it fixed on?
    S.E
    Quote Originally Posted by ncfcsignum View Post
    It's held on with lots (about a dozen or more) plastic clips. Allegedly they can be undone, but I found it easier to cut them off with a dremel, given that I wasn't going to be using the old trim again. Do it carefully and you don't damage the locating lugs on the bumper, so the new trim goes on fine.
    Regular Member James C's Avatar
    Essex
    Engine : 2.8 Turbo
    Kinda sticking on the theme, anyone know the size of the stock pre-facelift twin pipes? I've just ordered the lower valance today and want some stock-ish looking trims. Oh, and my local deal wanted just under £50 for the pre-facelift rear skirt.
    S.E
    Quote Originally Posted by James C View Post
    Get under the car and have a measure, also work out how long the new tailpipe trim needs to be, then contact MIJ and they can make you what you need, probably about £30 a side for something like 6"x4" oval stainless steel tips.
    Regular Member crespo's Avatar
    Bournemouth
    Or you could buy 2 of these.
    http://cgi.ebay.co.uk/OVAL-POLISHED-...es_CarParts_SM
    S.E
    Quote Originally Posted by crespo View Post
    Nowhere near long enough - they'll still be tucked under the bumper instead of intruding out.
    Full Member keefy*2010's Avatar
    Jul 2010
    Grain, Rochester,Kent
    Vehicle : Vectra C Facelift
    Engine : 1.9Cdti 150
    I have seen on fleabay
    angled stainless steel exhaust trims you will
    Need pipe diameters.
    Bournemouth
    How.
    You clamp them to the original exhaust pipe so you can have them as far in (until they touch the backbox) or as far out past the bumper as you like.
    You dont weld them to the backbox you know.
  1. 2.2 DTi twin exhaust conversion....?
    By blues n twos in forum Vectra C / Signum Car Chat
    Last Post: 25th February 2010, 16:12
  2. Right hand back box (for twin exit conversion)
    By John LE in forum Parts for sale
    Last Post: 23rd December 2009, 18:37
  3. WGO twin tank conversion?
    By jtg in forum Vectra C / Signum Car Chat
    Last Post: 16th May 2008, 08:31
