Thread: Moisture barrier question..
    Regular Member mickydoos's Avatar
    Aug 2009
    Crawley, West Sussex
    Default Moisture barrier question..
    Hi guys, I've got a silly question.
    I'm looking to do some sound proofing to my doors and to do this I've got to get to the inside of the outer door.
    Does anyone know if the moisture barrier is removable/refittable or do I have to just tear it out and reseal them somehow?
    OR is it absolutely necessary?
    Ive heard theories that the seal is necessary for the side impact sensors though how true that is I dunno.
    Eventually I'll be sealing by means of loads more proofing anyway :-)
    Thanks for the help!
    Aug 2010
    whitley bay
    if you mean the plastic sheeting- not really that nec. but if you use a blade and cut round 3/4 of it leaving the bottom attatched just tape it back up.
    if its foamy type sheeting use a blade and carefully peel back a corner and trim through the glue/sticky tape etc just use double sided tape to refit.
    Aug 2009
    Good job I have you lot to think on my behalf :-)
    Regular Member alzsxi's Avatar
    Maidstone, Kent
    You should be able to carefully peel the plastic sheet off but would need a contact adhesive to glue it back down.
  1. Would Moisture in Headlights fail an mot test
    By dti owner in forum Vectra C / Signum Car Chat
    Last Post: 17th February 2013, 01:27
  2. Brake dust barrier
    By John LE in forum Detailing and Car Care Discussion
    Last Post: 4th June 2012, 08:47
  3. Vaux-Com / Op-Com question - Screen change question
    Last Post: 16th May 2010, 23:54
  4. Pm Question
    By Happy Girl in forum The 'Off Topic' room
    Last Post: 27th December 2009, 18:21
  5. fog moisture.
    By payney in forum Vectra C / Signum Car Chat
    Last Post: 29th September 2005, 17:59
