Thread: Reversing sensor wiring
    Newport (Shropshire)
    Vehicle : Ford Kuga
    Trim : Titanium
    Engine : 2.0dtci
    Mileage : 1200
    Default Reversing sensor wiring
    Hi all, treated the vec to Maplins reversing sensor kit, after one bumper scrape too many.
    After reading and asking q's ok with the job, just got one query for those that have done it, is it easier to wire the display/beeper bit straight down the middle of the cabin, or sideways, under the dash and along the sill. Seem to have around 20ft of cable there to connect to control unit in boot.
    north east
    I cant answer your post but the clips that hold the back seat bench in are £8.50 each if you break one, So if you can find a route that doesnt need the rear seats lifting your probably on a winner.
    Regular Member nibblitz's Avatar
    Jul 2010
    Buckinghamshire
    Ive read some people put the display part on the back shelf so you view it in the rear view mirror, saves running wires up to front of the car..
    Regular Member Keithy's Avatar
    Jan 2008
    Dundee
    from the rear run the cable along the side until you get to the rear of the front seats. If you feel the back underside of the seat you will feel hook type things on the frame. pass the cable under the chair (using the hooks to hold the cable) towards the centre console and run along to the front. The cubby under the radio would be ideal mounting place.
    I dont have the display on my kit but this is the route i have used to power my 6x9's
    Hope this is of some help
    Regular Member crespo's Avatar
    Bournemouth
    Personally form my old car radio wiring days it is almost always easyer to run the wiring down the side (sill) of the car and up behind the glovebox.
    Vehicle : Ford Kuga
    Trim : Titanium
    Engine : 2.0dtci
    Mileage : 1200
    Quote Originally Posted by Keithy View Post
    Thanks Keithy, that cubbyhole is in fact where I intend putting it, so that's not a bad plan.
    Crespo, not disregarding yours yet, I've had to rewire pretty much all the stereos on my classics, some where easier down the side, some down the middle. Never done a Vec so getting a heads up lol
    Jan 2008
    Dundee
    Quote Originally Posted by Grumpy1954 View Post
  1. Reversing camera wiring help
    By wayne10244 in forum Electrical & ICE (including SatNav)
    Last Post: 19th August 2011, 17:45
  2. Reversing CAMERA -Wiring to Light help Needed
    By JACKALG1 in forum Electrical & ICE (including SatNav)
    Last Post: 7th June 2010, 08:22
  3. Replies: 1
    Last Post: 16th February 2006, 18:58
