Results 1 to 3 of 3
Thread: Excessive Road Noise / Rear wheel camber
    Regular Member ph67's Avatar
    Northamptonshire
    Default Excessive Road Noise / Rear wheel camber
    Had 2 Michilin HP Primacy 215/50 R17's fitted to the rear 3 years ago, they hardly had any wear on them after the first two years (as expected) but suddenly 1 year ago I notice the road noise level increasing in the rear of the car - thought the bearings might be going but no, they're fine. I now notice that the inside edge of both rears are wearing excessively - probably 4 mm on inside edge when the rest of the tyre has about 6mm on it.
    This sounds like negative camber from reading various threads around and from the fact that it's visible to my eye that both wheels lean in at the top and out at the bottom, so my question is: Can the VX dealer fix this or is a specialist the best route forward? - If the specialist is better then does anyone know a good one in south Northamptonsihire? - I ask as it has to go to the dealer shortly and prefer to get all done in one go...anyone got any thoughts? Ta
    West
    The wear on the inside edge of the tyre is a sign the rear upper control arms are on the way out... jack up motor & rock the wheel from left to right to check for play.
    it's not really a big job.. about half hours labour a side & £40 a side for the parts.
    hth
    Regular Member old cruiser's Avatar
    slough
    First check as dh.dti says and if all is good, could be woth a trip to WIM, they are in Chesham, not sure how far they are away from you, but people do travel miles from around the country to go there as they are an authority on Geometry , Tony Bones is the owner and what he doesn't know about Geometry ain't worth knowing and can set up your rear camber etc if needs be , here's their website www.wheels-inmotion.co.uk
    Cheers Pete
  1. Excessive road noise on some roads in Signum Design
    By jw128 in forum Suspension, Wheels & Brakes
    Last Post: 7th April 2012, 10:56
  2. excessive noise and poor performance ?
    By VecPower in forum Troubleshooting
    Last Post: 1st March 2012, 08:03
  3. Road spray noise from rear
    By CooLix in forum Vectra C / Signum Car Chat
    Last Post: 2nd February 2009, 00:15
  4. Road Noise / Rumbling rear wheels solved?
    By Raze in forum Suspension, Wheels & Brakes
    Last Post: 10th October 2008, 17:30
  5. Tyre noise excessive
    By videodoctor in forum Vectra C / Signum Car Chat
    Last Post: 22nd May 2007, 21:25
vectra c rock back wheel
