Thread: Boost Sensor Hex bolt Q
    Jul 2010
    Dublin
    Default Boost Sensor Hex bolt Q
    Hi Guys,
    I've been trying to get the boost sensor out to clean it properly but the Hex bolt is rounded out and an allen key won't do it anymore, Any ideas? Ive tried using a spanner and pliers at it but no joy. All I can thing now is to to cut across the top of the bolt and try to use a flat head to turn it. I have the 1.9 tdi 150 engine. I recently replaced the EGR with a new one but i can't the bolt for the boost sensor out to clean it.
    Any ideas? Wild n wacky all considered I just want my car back to herself.
    Cheers,
    R
    north east
    The fittign is a torx fitting you need torx bits to remove it, Your probably best off using mole grips on the head if you can get a grip of it and replacing with a new bolt.
    Regular Member kevcdti's Avatar
    North east
    as above get some mole grips on it then fit a new bolt,done mine yesterday and it wasnt that tight so should be easily removed,but f*** me it was badly caked up and took it for a drive afterwards and noticebly different
    Jul 2010
    Dublin
    Thanks Guys,
    Much appreciated!! Can't wait to get her flyin again. I brought it out last night and it was fine until I went to drive up a hill and it went into limp mode again.
    Jul 2010
    Dublin
    Righteo, I started the car up today and it was idling like a dog, all rough and juttering so I checked the injectors and when I pushed the 2nd one from the right hand side in the cars idling went very smooth. So i decided to bring it for a spin and it went like a bullet but then about 2 miles later when into limp mode again and was juttering and idling lumpy. So I popped the hood and pushed the plug on the injector again and the cars idling went fine again and it took of like a bullet again. Is this Injector number 3 that people talk about? And how much would it cost a garage to fix? I know theres a kit to do it myself but I don't feel comfortable doing it!
    Thanks all,
    R
    Engine : 1.9 CDTi
    Yes thats number 3.
    Not sure on price.
    West
    tie wrap it together until you get the part... i think it's about £15 for the part
    north east
    ^^ agree take the current connector off and clean with wd40 then refit and cable tie into place ;-)
    Jul 2010
    Dublin
    Thanks for that guys. I'll take a look at it when I get home tonight and see if I can hold it in someway. I've contacted garages for a price so just waiting for them to get back to me.
    Thanks for all your help.
  1. CDTi top boost hose close to bolt
    By lee gsi in forum Engine & Drivetrain
    Last Post: 31st August 2010, 18:53
  2. Boost valve torx bolt??
    By Governor in forum Vectra C / Signum Car Chat
    Last Post: 15th February 2010, 17:34
  3. CDTI 150, 10k Boost De-Coked & New Boost Sensor
    By Vaux-Man-G in forum Vectra C / Signum Car Chat
    Last Post: 4th January 2010, 12:02
  4. cleaned boost sensor and still shows over boost
    By chowwie in forum Engine & Drivetrain
    Last Post: 14th November 2008, 09:23
vectra c hex bolt
