Thread: Car pulling to the left? Tyres?
    Aug 2010
    Buckinghamshire
    Default Car pulling to the left? Tyres?
    Just purchased a 2yr old 1.8 SRi with 19k miles. Car seems to be in great condition. However, I noticed (2 days after buying it!) it's pulling to the left at speed (ie, when I let go of the steering wheel on a straight road).
    On checking the tyres it's running Goodyears all round (which are somewhat worn) apart from the front right which has a Continental tyre (with more tread that the others it seems).
    So I'm hoping it's pulling to the left because the Continental tyre has a greater rolling circumference than the Goodyear tyre on the front right.
    Is my logic sound?
    In which case I'll probably getting a new matching pair of tyres for the front.
    Will obviously check with the garage tomorrow - but thought I'd get an opinion from the forum. Think it's a bit naughty to stick brand new tyre on the front axle without changing the other especially given its a different make.
    Regards
    James
    Oct 2006
    Waterloo, Liverpool
    13 Post(s)
    Trim : SRI NAV XP
    Engine : 1.9 CDTI 150
    Mileage : 72K
    Yes tyres can make the car pull to one side. Happened to me when I changed my NCT5 fronts for a pair of part-worn F1's. OK in the dry, but pulling left when the rain came down.
    Changed the tyres back - problem solved.
    Put four identical tyres on the car, the most tread on the rear
    Inflate to correct pressures
    Book the car in for a Hunters Full Alignment Check, alignmycar.co.uk
    Compare
    Regular Member Si-SRI's Avatar
    Oct 2009
    LINCOLNSHIRE
    I have goodyears all round on my 08 plate cdti and a newer one of the near side front...i thought i had the same problem..pulling to the left so thought must be the newer tyre...
    Took it for a 4-wheel lazer alignment and jesus....the backs were of the scale.....toe and camber were miles out...once they were brought into line the fronts were brought more or less in line as well....a little tweaking on the fronts and sorted...
    Wheel noe straight...no more pulling...£45quid it cost me but worth every penny.
    Carmarthen
    Vehicle : Insignia
    Trim : Sri
    Engine : 140 Ecoflex S/S
    Rincage - get yourself down to http://www.wheels-inmotion.co.uk/index.php. Tony Bones is your man and will 100% sort out your problem
    Aug 2010
    Buckinghamshire
    Quote Originally Posted by gtr1000 View Post
    As luck would have it that's exactly where I'm going
    Carmarthen
    Vehicle : Insignia
    Trim : Sri
    Quote Originally Posted by Rincage View Post
    Let us know what happens?
    Aug 2010
    Buckinghamshire
    New tyres fitted this morning (x4 Kumho KU31 225/45 R17). All OK now it seems.
  1. Pulling to the left
    By coldo in forum Vectra C / Signum Car Chat
    Last Post: 26th February 2013, 18:17
  2. Pulling to the right, then left.. Help!
    By treadstone in forum Vectra C / Signum Car Chat
    Last Post: 16th January 2011, 18:06
  3. Pulling to the left
    By Danialj32 in forum Vectra C / Signum Car Chat
    Last Post: 1st November 2009, 21:52
  4. Pulling to the left
    By spennny in forum General Chat
    Last Post: 10th February 2009, 21:51
  5. Pulling to Left
    By Diet1985 in forum Suspension, Wheels & Brakes
    Last Post: 29th January 2009, 20:39
