Thread: Widest wheels on your C?
    Regular Member nick_s's Avatar
    Jul 2009
    Stoke on Trent
    Default Widest wheels on your C?
    Looking for some new rims to replace the snowies, and have seen a nice set of staggered rims. 235 front rubber, 265 at the rear. Would these fit without issue?
    Jun 2009
    South Coast
    Vehicle : Vectra and a Signum
    Engine : Z18XE,Z19DTH,Z20NET
    signumboy has 245 all round and i have 235 all round without probs.. Not sure about 265, i guess it coulkd be ok but somebody will confirm soon enough
    Jul 2009
    Stoke on Trent
    Yeah I am running 235's all round no probs, just the rears.
    I've seen similar rims running 245 rears so could be an option Ta!
    Regular Member signumboy's Avatar
    Edinburgh/outskirts
    Engine : 2.0 Ltr Turbo
    Mileage : 38000
    Quote Originally Posted by Caveman_nige View Post
    Think you might be struggling with the 265 ...not sure if anyone has tried it so you might be the first
    Sep 2009
    midlands
    i run 245s all round on my face lift, and they do slightly catch on the inner arch on full lock, n/s worse for some reason
    Jul 2009
    Stoke on Trent
    Cheers guys
    pokajedi, is yours lowered at all?
    Regular Member hagga's Avatar
    kingswinford
    theres loads of room on the rear,265s should squeeze on depending on the offset... theres a recent thread with someone running 20x10" rears.
    Aug 2010
    Norway
    Default 10x20
    hello .
    I have 10x20 rear (255/30) and 8,5x20 front(225/30)
    Front is no problem , rear i have ET35 and then i need 5mm spacer . Clearance is 1mm but it dont scrub .
    Sep 2009
    midlands
    Quote Originally Posted by nick_s View Post
    Cheers guys
    yes m8 45mm pi springs, which works out 30mm as the sri are already 15mm lower than std
  1. Structure wheels (Steel wheels that look like alloys)
    By lee gsi in forum Vectra C / Signum Car Chat
    Last Post: 12th October 2012, 21:24
  2. snowflakes, widest width tyre you can fit?
    By hairy31 in forum Handling & Braking
    Last Post: 14th February 2012, 13:11
  3. Replies: 18
    Last Post: 7th February 2012, 12:25
  4. Replies: 2
    Last Post: 17th November 2010, 22:45
