Results 1 to 10 of 16
Thread: upgrading vacuum & turbo hoses
    Liverpool
    Default upgrading vacuum & turbo hoses
    i didnt know weither to put this in engine or styling section, so thought i would play it safe and put it in here!
    I am after replacing/upgrading my hoses on turbo & vacuum hoses, does anyone know where to get them from & sizes?
    i know winnie had done vac hoses but i cant seem to find thread
    Liverpool
    Anyone?? My bank card is waiting lol
    Vehicle : Signum 2.0 DTi
    Trim : Elegance/Elite
    Engine : 2.0DTi
    Mileage : 73350
    Have a look on e bay for vacuum hosing , you need 2 mm tubing as for turbo hoses apart from some one making copies on e bay for the top two hoses for some of the engines there is none available at the moment apart from those supplied by vx
    and still loving it
    Liverpool
    There's alot to choose from on eBay, just wanted to narrow it down. From what I have seen, I think it's 4mm for the vacuum hosing. Just would like to know what the measurements would need to be for the main turbo hose
    Regular Member James C's Avatar
    Essex
    Engine : 2.8 Turbo
    Check out the suppliers of silicone hoses (only Samco springs to mind right now, but I know there are others) as they might have something in the works or be willing to use your motor as a development mule. They might even be interested in a group buy for the site. I think the 1.9 is a Fiat engine, so some of the pipes for the various Fiat group models might fit the Vec too.
    Liverpool
    Have had a look at samco ones from demon tweeks, might have to go down for a browse!
    Regular Member Innes's Avatar
    Plymouth
    Yes its 4mm for the 1.9cdti. You don't need very much of it. I originally put 4mm on my 2.2dti but actually needed to be 2mm for me. I recently fitted my spare 4mm to a members cars the other day and you dont need very much if you are replacing the two pipes at the front, probably 50cm if that. if you are going to replace the vacuum pipe from the turbo to the vacuum solenoid as well then you will need a couple of meters.
    With regards to the turbo/intercooler pipes you can buy moulded silicone replacements off ebay for the 2.2dti for £65. I assume you can get the same for the 1.9cdti. I recently had an intercooler hose split so instead of replacing it for £65 I made my own for about £30. This involves getting a tape measure out and some patience but it ends up looking pretty cool! I wouldn't like to do any complicated shapes this way though! heres my thread with pics:http://www.vectra-c.com/forum/showthread.php?t=116528
    Liverpool
    Cheers innes!
    I am after a similar set up/look to yours
    Vac pipes will be done on my next days off, might just have a mooch on the bay again, but I have eerrrm been sorta banned now so i can't do more than look, so probably be a demon tweaks road trip over weekend.
    Plymouth
    Quote Originally Posted by paul_sri150 View Post
    ...but I have eerrrm been sorta banned now so i can't do more than look
    You naughty boy! Well at least it'll give you a chance to do the mods.
    With a ban are you aloud to sit in the car with the key in the ignition so long as you dont drive off?
    May I ask what the ban was for or shall I keep my trunk out??
    colchester
    I tried 4mm silicone hosing on my 56 plate 1.9cdti 8v and it made it start badly and seemed to run worse!! Will try 3mm instead!
  1. 2.2 DTI vacuum hoses / pipe
    By Alistair123 in forum Engine & Drivetrain
    Last Post: 13th January 2012, 15:50
  2. 2.2DTi Y22DTR vacuum hoses scheme
    By Zemi in forum Engine & Drivetrain
    Last Post: 5th October 2010, 15:45
  3. Vacuum/turbo hose temp's
    By paul_sri150 in forum Vectra C / Signum Car Chat
    Last Post: 2nd September 2010, 19:16
  4. turbo hoses for dt1
    By excaliber76 in forum Vectra C / Signum Car Chat
    Last Post: 13th May 2009, 21:47
