Thread: DPF filling up too quick?
    Jan 2010
    Perkinsville, County Durham
    Trim : Sri nav
    Engine : Z19dth
    Default DPF filling up too quick?
    Just one thing i've found out, guys.
    Got my Vec at the end of last year (1.9cdti 150 estate, with DPF). A few weeks later i noticed it regen'ing now and then. Around 4 months ago, the car broke down with blocked DPF. Had it removed and replaced with a straight piece of pipe, then had the regen software removed from the ecu.
    In the last few weeks, the car has been smoking more and more. After making up a boost test kit, i found the boost was leaking out around the butterfly valves in the inlet (losing air meant that lots of fuel was exiting the engine as soot). I'd checked the valves operated ok not long after buying the car, but never thought about the boost leaking out. It seems to leak out from low revs, but once the turbo is really going, there seems to be enough air going into the engine to burn the fuel (although there still is a massive amount of air leaking out)
    If i hadn't removed my DPF i'd still be scratching my head and wondering why the DPF was filling so quickly, no doubt someone would have suggested a new DPF.
    So, if anyone is experiencing DPF's filling up and regen'ing too often, check for boost leaks!
    Its leaking around the swirl flaps on the inlet manifold then
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Engine : 2.0 TDI 184PS
    Mileage : 40000
    Looking at your profile you probably have the older manifold, unless you have had it changed.
    The oldermanifolds allowed the swirl flaps to move along their axis as well as rotate.
    Gazza4
    Jan 2010
    Trim : Sri nav
    Engine : Z19dth
    Yes.
    Jan 2010
    Trim : Sri nav
    Engine : Z19dth
    Quote Originally Posted by Gazza4 View Post
    The older manifolds allowed the swirl flaps to move along their axis as well as rotate.
    Gazza4
    I'm pretty sure it's on it's first manifold. The car was registered in late December 2006. It's done 74,000 miles, so it's had a fair bit of use. The top of the flaps have the hole in them (as opposed to the newer style tops)
  1. filling up with cooking oil
    By montyfert in forum The 'Off Topic' room
    Last Post: 13th August 2012, 20:56
  2. Filling up soon can I put this
    By dannyjpuk in forum Vectra C / Signum Car Chat
    Last Post: 25th December 2011, 18:22
  3. Filling a battery ?
    By rickeys16v in forum Vectra C / Signum Car Chat
    Last Post: 28th December 2010, 02:05
  4. Filling insert
    By willoftoon in forum Styling
    Last Post: 20th June 2009, 00:52
  5. Filling Up
    By VauxVeteran in forum General Chat
    Last Post: 16th January 2008, 04:13
vectra c 1.9 cdti dpf how to fill
