Thread: CDTi top boost hose close to bolt
    Engine : 1.9 CDTi
    Default CDTi top boost hose close to bolt
    Is there anyway I can move this hose away from the bolt as its just started to wear into the hose.
    How does everyone elses fit?
    Jan 2010
    Perkinsville, County Durham
    Trim : Sri nav
    Engine : Z19dth
    I'd be tempted to undo the left hand jubilee, pull the hose towards the front of the car, then tighten the jubilee.
    Engine : 1.9 CDTi
    Its clamped to a alloy pipe so I am not sure if it would move or not.
    When I get more time (Not driving the car at the moment) I will try and undo the right one and see if it will twist away from the bolt.
    north east
    Interesting place for a bolt im pretty sure someo people on here have had to replace that pipe and can only get it in the 3 sections from vaux .... think ill check mine later and put some insulation tape ove the head of the bolt or something similair
    Farnborough, Hampshire
    that bolt looks like it could be bent away from the pipe a lil bit with some small long nose mole grips???
    Vehicle : vectra-c
    Trim : sri
    Engine : cdti
    Mileage : 98,000
    Simple!, Loosen the lower jubilee clip, Twist the hose away from the bolt, Hold in place whilst Re- Tightening the lower clip!, common (another vx crap design)..
    Engine : 1.9 CDTi
    The bit its bolted to is welded to the pipe so wont bend.
    Loosening the bottom clip is what I was going to go for.
    Engine : 1.9 CDTi
    Loosened both clips off, pushed the hose 'down' and twisted it away and it now sits about a cm away so all sorted
    gonna go check mine right now actually, well spotted
  1. Boost hose
    By woody in shetland in forum Vectra C / Signum Car Chat
    Last Post: 9th December 2012, 09:58
  2. Boost hose clip size?
    By Ian-Highlander in forum Engine & Drivetrain
    Last Post: 1st April 2012, 17:14
  3. boost hose
    By leeroy in forum Diesel Engine related
    Last Post: 30th April 2010, 08:13
  4. Silicone boost hose for DTi?
    By fikse in forum Diesel Engine related
    Last Post: 6th February 2010, 17:55
top boost hose
