Thread: All F23s not the same???....
    Grantham
    Trim : LX
    Engine : 1.8 Petrol
    Default All F23s not the same???....
    following on from this thread
    http://www.vectra-c.com/forum/showthread.php?t=116606
    It seams that my problem was caused bu the mounting point for the central slave cylinder being higher in the relacement box to the existing, causing the clutch to be permanently engaged.
    Any ideas why these two boxes are different as they are both off 2.2 Vectra Cs
    http://i1019.photobucket.com/albums/...c/DSC02107.jpg
    http://i1019.photobucket.com/albums/...c/DSC02106.jpg
    Regular Member kenp's Avatar
    Kr. Hyllinge, Denmark
    Engine : 2.2 Direct
    I know theres atleast 3 different F23..
    2 5 speed ones and 1 6 speed one...
    the 5 speed ones are model year depending.. and i dont know when the 6 speed came..
    Regular Member benny's Avatar
    Feb 2006
    dudley
    all f23's are 5 speed ....but the f23 is a getrag box and is also fitted to other cars rover 75 springs to mind ......the f23 for the astra / zafira are different to the vectra b one's then the vectra c one's are also different ...the vectra c f23 i think has 2 different options the early z22se's and the later z22se's /z22yh fitting's
    EVERYWHERE
    Everything you need to know here> http://www.opel-infos.de/getriebe/f23.html
