Thread: Front wiper problems
    Jun 2009
    Brighton
    Default Front wiper problems
    Hello There. I have recently started to have a problem with the front wiper function of my CDTi150 estate (2005). On intermitent and slow spreeds the blades would move across the screen in a jerky manner and just stop at any random point in their movement. Now they do not work at all in these slow speed motions but full speed is absolutely fine and is the only setting I can use it on. If it works on fast it suggests to me the motor and lonkage must be fine. I presume there isn something controlling speed like a relay? Anyone know where it is or what it could be? The screen was motor does not work either unless fast speed on wipers is going too !!
    Sep 2010
    stockport
    Default front wiper motor
    my front wipers packed up last month. initially took it to a local auto electricians. they pluggeg it in and came back with nearly a grands worth of repairs. new motor, linkage and a S E N unit. they actually advised me to take it to a vauxhall dealer because they were unable to re-programme the unit and would charge me to tow the vehicle to the dealer for programming. my advice would be to take it and have it diagnosed. if it is thr S E N unit its quite expensive. i got away with a new motor and linkage it worked out a £324. good luck.
    Regular Member Ollie's Avatar
    Jan 2010
    Towcester
    Engine : 1.9 CDTi (150)
    Mileage : 126000
    There are lots of threads on here relating to this issue. It mostly seems to happen when it's very cold (i.e. below zero).
    Regular Member AdeyCorp's Avatar
    Chesterfield
    I have this same problem, So is the only advice is to take it to a garage?
    Regular Member 111's Avatar
    Stockton-on-Tees
    The motors are 95% to blame & are less than £70 new off ebay and it is a common problem just like on the corsa C's, it is a copper arm inside the motor that snaps off then the motor doesn't know the correct place to stop even though sometimes it will work on other speeds, takes about 1 1/2 hours to change.
    preston
    i think you'll find that if its very cold, and your screenwash is diluted then it can freeze in the pump / outlet pipe. if this happens the wipers will fault in the way you describe.
    On cold mornings i make an old 500ml coke bottle up with 50% wash 50% warm water. this has cured this problem now
    hope this is the cause of your problem
    but at least its a cheap and quick fix before you go to the garage
    Nov 2010
    Dudley
    I have the same problem!! I took it to Vauxhall this morning, who told me to buy a new fuse. After reading these posts, I can argue the toss with them now. Brilliant
  1. Wiper problems - front and rear 2004 1.8 sri
    By wired89 in forum Electrical & ICE (including SatNav)
    Last Post: 21st November 2012, 16:29
  2. Front Window Wiper problems... Random!?
    By Chunklamb in forum Electrical & ICE (including SatNav)
    Last Post: 30th April 2012, 14:56
  3. Wiper problems
    By stripey in forum Vectra C / Signum Car Chat
    Last Post: 1st February 2010, 12:34
  4. Wiper problems?
    By In a states in forum Vectra C / Signum Car Chat
    Last Post: 14th December 2006, 18:26
vauxhall vectra c wiper problems
vectra c wiper motor relay location site:www.vectra-c.com
