Thread: Cdti pre cat removal
    Regular Member winnie2457's Avatar
    kings lynn, norfolk
    Default Cdti pre cat removal
    Hi guys a few questions does my vec estate have a pre cat as well as the dpf?
    If yes where is it located?
    And is it easy to remove and drill the insides out to make it a straight through pipe like I did with my dpf which also is the cat too
    I can't see any trace of a pre cat in the underside of the car and is there any sensors on it could I knock the I sides out and is it easy to remove
    Cheers hope to hear soon guys thanks
    EVERYWHERE
    Pre-cats are usually very close to the exhaust manifold (sometimes they are in the exhaust manifold). They need to warm up quickly so that they trap noxious gases when the engine is warming up. An unintentional side effect of the pre-cats is that they are actually beneficial to turbo reliability (work it out for yourself ).
    The 'cats' also reduce soot. Something to think about come MOT time.
    The 'cats' convert CO to CO2 and Hydrocarbons (a mixture of poisonous gases) to H2O and CO2. They also reduce soot emissions.
    They used to be very restrictive, but modern ones hardly affect performance or fuel economy at all. But that hasn't stopped people from removing them anyway.
    However, like any emissions device they don't do too well when asked to deal with unburnt fuel, so maybe that's why you want to remove it?
    Regular Member mozzer99's Avatar
    bristol
    On my 2005 estate (150 CDTI) it appears the cat is part of the DPF. The DPF is in two halves internally, the first bit is the cat and the second bit the DPF.
    AFAIK or can see there is no other CAT or precat.
    If you look through the hole I drilled in the CAT you can see the DPF behind it.
    Jan 2010
    Perkinsville, County Durham
    Trim : Sri nav
    Engine : Z19dth
    There IS a pre cat, and like dd says, it's just after the turbo.
    kings lynn, norfolk
    Ok so I must have one I know I have removed my dpf already so I now have no cat/dpf only one rear silencer I wish to get the exhaust as free flowing as possible
    So I wish to remove the pre cat and drill it out so it's straight through
    Question time lol
    Is the pre cat straight in shape so you can drill through
    How do you remove it. Is it a bumper off job and is it just bolted on like a flange both ends
    Has any one removed it in this way before on here thanks hope you guys can help thanks again
    Jan 2010
    Trim : Sri nav
    Engine : Z19dth
    It sould be easy to drill/smash out. Just remove the splash guard, under tray thingy. There's 3 bolts holding it onto the turbo, then i'm sure that section leads back to a join just before the DPF.
    For the size of the pre-CAT, an exhaust place shouldn't charge more than £50 to replace. It's literally 250mm long.
    kings lynn, norfolk
    i am servicing my car on thur night so i will have a good look at it then and see if i can remove it and gut the insides too cheers mally
    have you removed yours before??
    would i see better turbo spool up and more turbo whislte through the exhaust thanks
    kings lynn, norfolk
    hi last night i had a go at this and i could not get the turbo heat shield off without taking off the bumper and i didnt want to start that so i took off the flexi exhaust from dpf to pre cat so i could see into the precat and it is only about 4inches long the actual cat part of it
    so i was going to drill through it in situ on the car to free up the flow abit but when i started drilling it is not the ceramic material as is the main cat which drills really easily it is like a metal honey comb which crushes rather than drills through.
    i now have a drill indent on my pre cat the size of a 5 pence which is blocking it a 5p size i dont think it will make much difference but should i try a sharper titanium drill and a smaller diameter to see if i can drill through
    i just cant get it off the car on my drive cheers
    kings lynn, norfolk
    Bump thanks
    kings lynn, norfolk
    Bumper bump lol
    Any on at all help menon my last post
  1. ECU Removal - CDTI 150 facelift
    Last Post: 3rd February 2013, 22:26
  2. Cdti turbo removal
    By jofenan in forum Engine & Drivetrain
    Last Post: 8th May 2012, 18:09
  3. cdti 120 Thermostat removal
    By wrighty11 in forum Engine & Drivetrain
    Last Post: 12th April 2012, 09:06
  4. DPF removal companies for 3.0 CDTi
    By zerocool in forum Engine & Drivetrain
    Last Post: 11th December 2011, 01:07
  5. EGR removal on cdti 150 again !
    By aps in forum Engine & Drivetrain
    Last Post: 28th January 2011, 14:27
vectra c cat removal
how many cats does a vectra have
1.7 cdti pre cat drilling
vectra cdti 150 cat removal
vectra c cat location
vectra cdti with pre cat removed
Vectra cdti 120 precat
vectra y30dt cat removal
how to replace a pre cat
vectra cdti precat
vectra c pre cat removal
vectra cdti pre cat removal
z19dth turbo removal
vauxhall vectra cdti 150 pre cat removal
vectra 3.0 cdti how many cats
pre.cat on vectra c cdti
vauxhall vectra cdti pre cat
z19dth pre cat blocked
vectra 3.0 cdti precat
